Sustitución del condensador
6 Respuestas 1 Puntaje |
Porqué no espuma la leche mi cafetera Oster Prima latte II? |
1 Respuesta 0 Puntaje |
Mi cafetera no expulsa agua |
3 Respuestas 0 Puntaje |
Pierde agua al hacer el café |
Es necesario cambiar el pistón cuando pierde agua? |
Documentos
Partes
- Delonghi Water Tank - AS13200250
- Delonghi Rubber Cleandisk (Black) - AS00001634
- Delonghi Filter 1-Dose Coffee with Rib - AS00002564
- Delonghi Glass Carafe - HZ1029
- Delonghi Water Tank - AS13200251
- Delonghi Carbon Filter - 7313285779
- Delonghi Infuser Diffuser Kit - 7313251451
- Delonghi Infusion Kit with Black Push Button - 7313251441
Herramientas
Modelos
0132301056, 3057, 4185, BAR12, BAR12FU, BAR140, BAR18, BAR32, BAR390, BAR41, BAR42, BAR42E, BAR51, BAR52, BAR6U, BAR8IU, BAR9I, BARM100U, BARM29U, BCM8450UC Mostrar 272 más
BCM8450UC/03, BCM8450UC/04, BCM8450UC/05, BCM8450UC/09, BCO110, BCO120T, BCO130T, BCO264B, BCO320T, BCO330T, BCO430, BCO430BM, BCO432, BCO70, CAM51015B, CAM51025MB, CAM51035M, CC100IU, CM041, CM044, COM530M, COM532M, D14, D31, D4B, D612, D650, D660, D665, D895, D895C, D895UX, D986, DC312T, DC412T, DC412TTC, DC414T, DC514T, DCF210TTC, DCF212T, DCF2210TTC, DCF2212T, DCF6212TTC, DCF6214T, DCM020ST, DCM024BK, DCM025GR, DCM028, DCM029, DCM02BK, DCM02BL, DCM02GR, DCM02OR, DCM02RE, DCM02ST, DCM040, DCM041, DCM043, DCM044, DCM045, DCM047, DCM048, DCM049, DCM04RE, DCM1385OR, DCR902T, DE40P, DE50P, DE650P, DEN500P, DES020, DES020S, DES021, DES023, DES024, DES025, DES027, DES028, DES029, DFH233, DH100P, DH40P, DO1279, DO1280S, DO1289, EAM3200, EAM3300, EAM3400, EAM3400N, EAM3500, EAM3500N, EAM4000, EAM4000B, EAM4400, EAM4500, EC140B, EC140BEXC, EC155, EC220CD, EC260BK, EC270, EC330, EC460, EC5, EC5W, EC6, EC610, EC680BK, EC680BM, EC680BMC, EC680M, EC680M Dedica, EC680R, EC680R Dedica Red, EC685BK, EC685BK Dedica Deluxe, EC685M, EC685M Dedica Deluxe, EC685R, EC685R Dedica Deluxe, EC685W, EC685W Dedica Deluxe, EC700, EC701, EC702, EC710, EC730, EC860, EC885M, EC9155MB, EC9335BK, EC9335M, EC9335R, EC9335REX4, EC9355M, EC9665M, ECAM22110B, ECAM22110SB, ECAM23120SB, ECAM23120SBS11, ECAM23210B, ECAM23210SB, ECAM23260, ECAM23260SB, ECAM23270S, ECAM23450SL, ECAM23460, ECAM25462S, ECAM26455M, ECAM28465B, ECAM28465M, ECAM28465MD, ECAM29034SB, ECAM29043SB, ECAM29063SB, ECAM29084SB, ECAM35020B, ECAM35020W, ECAM35025SB, ECAM35075SI, ECAM37095TI, ECAM44660B, ECAM45055S, ECAM45760B, ECAM46860S, ECO310BK, ECO310R, ECO310W, ECP3120, ECP3220, ECP3220R, ECP3220W, ECP3420, ECP3620, ECP3630, EDG455, EDG656TEX1, EMF2BK, EMFIBK, EMK6, EMK6A, EMK6YL, EN267BAE, EN520B, EN520BEX1, EN520R, EN560S, EN680M, EN750MB, EO12001B, EO1200B, EO1238, EO1251, EO1258, EO1260, EO1270, EOP2046, ESAM04110B, ESAM04110S, ESAM2000, ESAM3300, ESAM3300EXD, ESAM3300EXHD, ESAM3300S, ESAM3500, ESAM3500N, ESAM4400, ESAM4500, ESAM5400, ESAM5500, ESAM5500B, ESAM5500M, ESAM5600, ESAM5600SL, ESAM6600, ESAM6620, ESAM6700, ESAM6900, ESAM6900M, FH1130/1BK, FH1163/1BK, FH1363/1BK, ICM17270, KF180BLACK, KF180TITAN, KF180WHITE, KF510, KF5350BK, KF5350WH, KF550, KF5650BK, KF580, KF600, KF600BLACK, KF600WHITE, KF6031BK, KF6050WH, KF7000BK, KF7070SI, KF7150BK, KF7155, KF7170BK, KF7170SI, KF7175, KF7370SI, KF9050BK, KF9070SI, KF9150BK, KF9150WH, KF9170SI, KG521M, KMM30BLACK, KMM30WHITE, KSM2, KSM4, M810, M850, M870220W, M870280W, M880220W, M880280W, MR310, MR330, MR400, MR430, PACT100P, PACT110P, PACT140HPEC, PENTA, TA1200, TA1400, VVX1470GA
Generalidades
Las cafeteras son aparatos diseñados para preparar café cómodamente en casa o en establecimientos comerciales. Las hay de varios tipos, y cada una emplea métodos diferentes para extraer los sabores de los posos del café.
Tipos
Cafeteras de goteo
Cafeteras vertedoras
Las cafeteras vertedoras son aparatos de preparación manual que permiten a los aficionados al café tener más control sobre el proceso de preparación. El diseño básico consiste en un embudo o gotero en forma de cono, que sostiene un filtro de papel o metal. Se coloca café molido en el filtro y se vierte agua caliente sobre él de forma lenta y controlada.
Cafeteras de goteo automático
Las cafeteras de goteo automático, también conocidas como cafeteras automáticas de goteo, son unos populares dispositivos de preparación eléctrica diseñados para ofrecer comodidad y facilidad de uso. Las cafeteras de goteo automático automatizan el proceso de preparación. Añades agua a un depósito, colocas el café molido en una cesta con filtro y enciendes la cafetera. El agua se calienta y gotea sobre el café molido. El café pasa a través de un filtro a una cafetera o jarra, que se coloca sobre una placa calefactora para mantener el café caliente. Algunos modelos ofrecen funciones como el ajuste de la intensidad de la infusión y el tiempo de espera.
Cafeteras de infusión
Cafeteras de infusión en frío
Las cafeteras de infusión en frío son aparatos diseñados para preparar café en frío de forma sencilla y eficaz. Suelen remojar granos de café molidos gruesos en agua fría o a temperatura ambiente durante un periodo prolongado, normalmente de 12 a 24 horas. El resultado es un concentrado de café suave y menos ácido que puede diluirse con agua o leche antes de consumirlo. Estas máquinas suelen llevar un filtro o un sistema de malla para separar los posos, lo que hace que el proceso de preparación sea cómodo y no ensucie.
Prensas francesas
Una prensa francesa es un dispositivo sencillo y eficaz para preparar café. Consiste en un recipiente cilíndrico de cristal o acero inoxidable con un émbolo y un filtro de malla metálica. Para hacer café, los granos de café molidos gruesos se remojan en agua caliente dentro de la prensa. Tras unos minutos, se presiona el émbolo hacia abajo, separando los granos del café preparado. Este método permite obtener una taza con cuerpo y sabor, ya que los posos de café permanecen en contacto directo con el agua durante el proceso de infusión.
Cafeteras turcas
Las cafeteras turcas, conocidas como cezve o ibrik, son recipientes tradicionales diseñados para preparar café turco. Estas pequeñas ollas, normalmente de cobre o latón, tienen un mango largo y una base ancha. El café finamente molido, el agua y el azúcar (opcional) se combinan en el cezve y se calientan a fuego lento. El singular proceso de elaboración consiste en llevar la mezcla a ebullición varias veces, creando un café fuerte y concentrado con una espuma espesa llamada "kaymak". Los granos de café finamente molidos se depositan en el fondo, ofreciendo una experiencia cafetera distintiva y rica.
Cafeteras a presión
AeroPress
La AeroPress es una cafetera compacta diseñada para ser sencilla y versátil. Consta de una cámara cilíndrica con un émbolo y una tapa de filtro. Para preparar café, los usuarios colocan posos de café y agua caliente en la cámara, remueven, colocan la tapa del filtro y presionan el émbolo para extraer el café. Su diseño único permite una preparación rápida y fácil, y es conocida por producir una taza de café suave y rica con control sobre las variables de preparación. La AeroPress es popular entre los entusiastas del café por su portabilidad, asequibilidad y capacidad para experimentar con distintas técnicas de preparación.
Olla Moka
Una Moka Pot es una cafetera de cocina que prepara un café fuerte y sabroso haciendo pasar agua hirviendo presurizada por vapor a través del café molido. Consta de una cámara inferior para el agua, un embudo central para los posos de café y una cámara superior para la infusión final. A medida que el agua se calienta, la presión la hace pasar a través de los posos de café, produciendo un café rico y concentrado conocido como Moka. El proceso es sencillo, rápido y popular por su capacidad de crear un café robusto con un sabor característico, algo parecido al del espresso.
Cafeteras monodosis
Las cafeteras monodosis son aparatos compactos y prácticos diseñados para preparar raciones individuales de café. Utilizan cápsulas o monodosis de café preenvasadas, lo que permite a los usuarios preparar rápida y fácilmente una sola taza de café con el mínimo esfuerzo y suciedad. Estas máquinas ofrecen una gran variedad de opciones de café, adaptadas a distintos gustos, y son favoritas por su sencillez y eficiencia en el tiempo.
Cafeteras Expreso
Las cafeteras expreso, conocidas comúnmente como máquinas de café expreso, son aparatos especializados diseñados para preparar café concentrado haciendo pasar agua caliente a través de granos de café finamente molidos. Funcionan a alta presión, normalmente unos 9 bares, para extraer ricos sabores y compuestos aromáticos de los granos de café. El expreso se caracteriza por su sabor fuerte y atrevido, así como por una capa de crema, una espuma cremosa que se forma encima. Estas máquinas son de varios tipos: manuales, semiautomáticas y automáticas, y ofrecen a los usuarios distintos niveles de control sobre el proceso de preparación.
Cafeteras totalmente automáticas
Las cafeteras totalmente automáticas son aparatos avanzados que agilizan el proceso de preparación del café. Estas máquinas se encargan de todo, desde moler los granos de café hasta la preparación, eliminando la necesidad de intervención manual. Los usuarios pueden personalizar factores como el tamaño del molido, la intensidad del café y el tipo de bebida, ya que estas máquinas pueden producir una gran variedad de bebidas, como expreso, capuchino, café con leche y café normal. Con molinillos integrados y sistemas de preparación automatizados, ofrecen comodidad y consistencia, proporcionando café recién hecho con el mínimo esfuerzo.
Percoladoras
Las cafeteras de percolador son dispositivos de preparación tradicionales que constan de una cafetera, un tubo central y una cesta perforada. El agua de la cafetera se calienta y la presión resultante la empuja hacia arriba por el tubo y sobre los posos de café de la cesta. A continuación, el café vuelve a la cafetera, creando un ciclo continuo hasta alcanzar la intensidad deseada. Las percoladoras fueron populares en el pasado, pero han sido sustituidas en gran medida por las cafeteras de goteo debido a las diferencias en los métodos de preparación y las preferencias de sabor.
Cafeteras de sifón
Las cafeteras de sifón, también conocidas como cafeteras de vacío, emplean un método de preparación visualmente cautivador y basado en la física. Consta de dos cámaras, en la inferior se calienta el agua, creando una presión de vapor que obliga al agua a desplazarse a la cámara superior, donde se colocan los posos de café. Cuando se apaga el calor, el café elaborado vuelve a la cámara inferior por efecto del vacío. Este proceso da como resultado un café único y aromático, de sabor suave y limpio, que resalta los sabores de los granos.
Información adicional
Un agradecimiento especial a estos traductores:
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
