Saltar al contenido principal
1 diagrama
Herramientas
Estas son algunas de las herramientas comunes que se utilizaron para trabajar en este dispositivo. Es posible que no necesites todas las herramientas para cada procedimiento.
Modelos
P214
Background
The Ryobi P214 is a cordless hammer drill/driver that operates on an 18V lithium-ion battery. Introduced in 2019, it is part of the One+ system by Ryobi, which allows for battery interchangeability across a range of power tools. The P214 is equipped with a 1/2 inch (13mm) chuck, delivers torque up to 600 in-lbs, and operates at two no-load speeds of 0-400 and 0-1600 revolutions per minute (RPM). Additionally, it is capable of delivering 0-24,000 blows per minute (BPM) and features 24 clutch settings plus a drill/drive mode.
This hammer drill includes a brushless motor, a 1/2 inch all-metal ratcheting chuck for bit retention, and a 2-speed gearbox that allows for adjustment based on the material at hand. It also features a hammer function, useful for masonry drilling. For user comfort and control, there is a GripZone overmold grip. The drill also includes onboard bit storage and is compatible with all One+ 18V batteries and chargers by Ryobi.
Technical Specifications
  • Model Number: P214
  • Power Source: 18V lithium-ion battery
  • Chuck Size: 1/2 inch (13mm)
  • Torque: 600 in-lbs
  • No Load Speed: 0-400/0-1600 RPM (2-speed)
  • Impacts Per Minute: 0-24,000 BPM
  • Clutch Settings: 24 + drill/drive mode
  • Dimensions: 7.5 x 8.5 x 4 inches
  • Weight: 3.9 lbs (tool only)
Warranty
The Ryobi P214 Hammer Drill comes with a 3-year limited warranty. This warranty is designed to cover any defects in materials and workmanship that may occur during this 3-year period, starting from the date of purchase. However, it's important to note that this warranty does not extend to cover normal wear and tear or damage caused by misuse or abuse. To claim the warranty, it is usually necessary to provide proof of purchase and report the defect within the warranty period. Specific instructions on how to claim the warranty should be included with the product or can be found on Ryobi's official website.
iRobot
Miembro Desde 09/24/09
1 Reputación
636 Guías creadas
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 28
Todo El Tiempo: 610
