Saltar al contenido principal
Ryobi Compact 18 Volt Hammer Drill P214 Housing Assembly Replacement
Qué necesitas
  1. Ryobi Compact 18 Volt Hammer Drill P214 Housing Assembly Replacement, Battery: paso 1, imagen 1 de 3 Ryobi Compact 18 Volt Hammer Drill P214 Housing Assembly Replacement, Battery: paso 1, imagen 2 de 3 Ryobi Compact 18 Volt Hammer Drill P214 Housing Assembly Replacement, Battery: paso 1, imagen 3 de 3
    • Detach the battery unit from the drill body and pull the battery outwards.
    • If the battery doesn't disconnect easily, gently wiggle the battery back and forth until it comes out.
  2. Ryobi Compact 18 Volt Hammer Drill P214 Housing Assembly Replacement, Housing Assembly: paso 2, imagen 1 de 1
    • Remove ten 13.5 mm screws from the drill casing using a Phillips #2 screwdriver to gain access to the interior.
  3. Ryobi Compact 18 Volt Hammer Drill P214 Housing Assembly Replacement: paso 3, imagen 1 de 3 Ryobi Compact 18 Volt Hammer Drill P214 Housing Assembly Replacement: paso 3, imagen 2 de 3 Ryobi Compact 18 Volt Hammer Drill P214 Housing Assembly Replacement: paso 3, imagen 3 de 3
    • Grab the sides of the housing and pull straight up until the housing pulls away revealing the inside assembly.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 185
