Saltar al contenido principal
Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement
Qué necesitas
  1. Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement, Battery: paso 1, imagen 1 de 3 Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement, Battery: paso 1, imagen 2 de 3 Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement, Battery: paso 1, imagen 3 de 3
    • Detach the battery unit from the drill body and pull the battery outwards.
    • If the battery doesn't disconnect easily, gently wiggle the battery back and forth until it comes out.
  2. Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement, Housing Assembly: paso 2, imagen 1 de 1
    • Remove ten 13.5 mm screws from the drill casing using a Phillips #2 screwdriver to gain access to the interior.
  3. Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement: paso 3, imagen 1 de 3 Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement: paso 3, imagen 2 de 3 Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement: paso 3, imagen 3 de 3
    • Grab the sides of the housing and pull straight up until the housing pulls away revealing the inside assembly.
  4. Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement, Trigger: paso 4, imagen 1 de 3 Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement, Trigger: paso 4, imagen 2 de 3 Ryobi Compact 18 Volt Hammer Drill P214 Trigger Replacement, Trigger: paso 4, imagen 3 de 3
    • Gently lift the battery clip to gain access to the trigger.
    • You can now clean any debris blocking the trigger.
Conclusión
Robert Campbell
Miembro Desde 02/09/23
73 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 257
