Saltar al contenido principal
Índice
Wiki con Contribuciónes de Estudiantes
Esta wiki ha sido creada por un increíble grupo de estudiantes de nuestro programa educativo.
If you Eureka SuctionSeal Pet vacuum is plugged in and powered on but the brush roller does not spin, follow this troubleshooting guide.
Brush Roller Drive Belt is Damaged
The drive belt is responsible for transferring power from the drive motor to the brush roller
Brush Roller is obstructed
During normal use of the vacuum the brush roller can become clogged with hair, carpet fibers, and other objects from the floor.
  • Activate vacuum head release handle to lower vacuum head and lay vacuum down for easy access.
  • If the brush head appears to be clogged, use scissors or a sharp tool such as a box cutter to carefully cut away debris and remove by hand.
  • If the brush roller appears to be damaged, remove and replace the brush roller with a new one.
Drive motor is burned out
Long term or frequent use can cause the drive motor to become damaged or seized.
  • Remove the cover from the head of the vacuum and remove the drive belt from the motor.
  • If the brush roller is able to spin freely independent of the motor the motor may be seized internally.  If this is the case a a new motor can be installed and the belt reattached to resolve the issue.
Scott Turnham
Miembro Desde 10/24/24
255 Reputación
2 Guías creadas
Equipo
Cuesta, Team 60-2, Krynen Fall 2024 Miembro de Cuesta, Team 60-2, Krynen Fall 2024
CUESTA-KRYNEN-F24S60G2
Miembros de 4
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 45
