Saltar al contenido principal
The Dell OptiPlex 745 small form factor is a compact desktop computer that has been a work office favorite, and still sits at desks to this day.
Preguntas 16 Ver todo
Why is my CD drive not opening?
When I press the CD drive button it does not open what to do?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario
@rufiniqbal what have you checked? Do you have power to the optical drive (CD drive)?
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Hi @rufiniqbal
Check if the cd drive tray opens if you click on the eject setting for the drive in Win Explorer.
Go to Win Explorer (press the Win key + e key - both together) > This PC > right click on the CD drive icon > eject.
It it opens OK, then the eject button on the drive may be faulty.
If it doesn't open, then there may be a problem with the tray motor or the drive electronics and further testing would be required to find the problem.
Fue útil esta respuesta?
Puntuación 1
You can try to force restart the computer
if that does not work, if there is a small manual opening hole in the drive door you can put a sim ejector tool into that to manually open it.
Or just stick a jimmy tool and pry until you can pull it out with your fingers
Puntuación 1
Añadir tu respuesta
Rufin Iqbal estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 51
