Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Las torres medias ATX tienen la misma construcción general y partes que otras torres de ordenadores de tamaño medio
Why is my computer restarting when playing game?
I recently purchased Spyro Trilogy for PC.
30 to 40 minutes into gameplay, my computer restarts. No blue screen, no indication.
Temps on CPU + GPU are within normal range. Thermal paste has been changed too.
There is no visible sign of damage on the motherboard, or burning odour. Fans operating normally too.
Harddrive has been scanned for bad sectors, but it is completely fine.
**Another thing that happened is, after the comp restarted, I went back into Spyro, and another reset occurred, but this time, the computer fell into a bootloop. I had to turn it off for about an hour before starting it back up. I thought it may have been a thermal issue, but the temps have always been in normal range.
Es esta una buena pregunta?
Puntuación 0
1 comentario
After playing like 30 min my pc restarts for no reason. I already swap the PSU and still have this issue. If i play apex after 5 mins of gameplay my pc restarts.
28/08/2020 13:48 Windows Error Reporting Fault bucket 2186734830684376627, type 5
Event Name: WUDFHostProblem
Response: Not available
Cab Id: 0
Problem signature:
P1: HostProblem
P2: HostTimeout
P3: 2
P4: 2.31.0
P5: 103
P6: 3
P7: 11b00
P8: ffffffffffffffff
P9: HID\VID_046D&PID_0AAA&REV_0031&MI_03&Col02
P10:
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER1B14.tmp.WERInternalMetadata.xml
These files may be available here:
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\NonCritical_HostProblem_9f463d374487d452c72ef539a5dc57e9af2cb33_00000000_e75e2d84-6bad-49e2-b2ad-15f0291b7827
Analysis symbol:
Rechecking for solution: 0
Report Id: e75e2d84-6bad-49e2-b2ad-15f0291b7827
Report Status: 268435456
Hashed bucket: 07f4501cd26ee2403e58d7be20ea8e33
Cab Guid: 0
- de
Agregar un comentario
4 Respuestas
Solución Elegida
Hi @lokikhan ,
the restarting PC is usually caused by hardware crash (collapse) or unexpected system thread stopped. The first case is easy to “demonstrate”. If we will think about the system crash, it doesn’t mean that you will automatically get an issue with a blue death.
System or software crash:
  • Run the Event Viewer on your PC
  • Select the Windows Logs
Then select the categories for view any issue or messages, so start by clicking on the first Application category and search for the issue in time, when your PC goes to restart. After you check the first category, proceed to the another. If you will find any issue, you can post the logs here to see what you can do, otherwise insert error message to google and find the solution there.
Hardware issue
  • Download Stress Test for the HW
In several times, the stress test is a complex application, which can measure the performance and temperature in real-time during the high-performance test. If some hardware is about to crash, the stress test will show you the issue and you can easily solve the issue. There are a lot of versions of Stress Test software, find the best one for your PC. You must check the performance of GPU, CPU and RAM.
After you will be done, post some result from your investigation.
Fue útil esta respuesta?
Puntuación 2
10 comentarios:
First thing's first, thank you for the swift reply, Lucas.
I forgot to add some info about this.
I have, in fact, run a stress test twice. I've tried 3DMark, and Maxon Cinebench. The computer didn't crash in either of those. If you have any other recommendations, I will gladly try them out and post results here. I will also Google some more tomorrow.
Also, the game I was having issues with actually functioned properly when I reduced the frame rate from 60 to 30.
I'll revert the frame rate back to 60 tomorrow to create the 'reboot' environment to get the appropriate info from the Event Viewer, however, when we checked the EV the last time, my techy friend couldn't find a defined problem in them. There is a log that the PC did reboot, but no reason was given. I'll get you a fresh copy though.
Apologies for leaving all this info out, and thanks again!
- de
I bet it's the power supply that is causing the problem.
The turning off for an hour is a sign of the PSU triggering it's overload protection, most likely due to it not being able to handle the load.
Replacing it with a good one should fix the problem. Something like a 550W 80+ gold PSU will do the job.
- de
@benjamen50 That's 2 for the power supply. Someone else mentioned that as well. Thanks, Ben. I'll see if I can get my hands on a PSU for test purposes.
- de
@lucasjak Hey Lucas. I'm trying to post the event logs on here, but it keeps marking them as spam for some reason. Any other way to get the logs sent to you?
- de
So, this time, my computer restarted outside of Spyro. Event logs are the same as before, and both times, DistributedCOM was part of the errors.
I don't know if that helps.
- de
Mostrar 5 comentarios más
@Vlad pennys
You don't give the system specifications of your computer e.g. RAM, CPU, motherboard etc but given that the Event Name is WUDFHost Problems, this link may be where to start
Puntuación 2
2 comentarios:
Thank you for answer
Specs:
GPU: Amd 5700xt tuf
PSU: Corsair rm750x gold
RAM: Corsair 16 gb ram dual channel, 3000mhz
Motherboard: B450 prime plus
CPU: Amd Ryzen 3600 with stock cooler on it
And i also forgot to specify that i tried to change ram and it also restarts...
- de
Have you fix it already? I had a same problem like you. Same spec.
- de
0x124_0_AuthenticAMD_PROCESSOR_Bus_BANK1_MSCOD060C_MCACOD0859_UC_IMAGE_AuthenticAMD.sys
0
BlueScreen
Not available
dec56aaf-33b9-45e9-8314-730ec2ce40e7
124
0
ffffe201c4403028
fc800800
60c0859
10_0_19042
0_0
768_1
\\?\C:\Windows\Minidump\051121-6578-01.dmp \\?\C:\Windows\TEMP\WER-12156-0.sysdata.xml \\?\C:\Windows\MEMORY.DMP \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER38D4.tmp.WERInternalMetadata.xml \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER38D5.tmp.xml \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER38D4.tmp.csv \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER38E5.tmp.txt
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Kernel_124_1621be44d8f515e98cfa6bd8b2d010c16f127e8f_00000000_cab_6670ccb7-b329-491a-bdeb-1f9b4d5bb56a
0
0ff9ab74-28c7-43d8-9d96-6944227830f7
268435462
0
Puntuación 0
Almost every Windows machine has Realtek HD Audio Manager installed along with the High-Definition (HD) Audio Driver. For odd and unknown reasons, it occasionally refuses to open or work properly. Worse even, the Audio Manager vanishes, particularly following a Windows upgrade or any malware that may be the source of the problems. Visit this link to learn how to fix it. realtek hd audio manager missing
Puntuación 0
Añadir tu respuesta
Loki Khan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 76
Todo El Tiempo: 18,782
