Saltar al contenido principal
Portátil empresarial de nivel básico presentado por Dell en 2014. Utiliza procesadores Intel Haswell (cuarta generación).
Preguntas 15 Ver todo
Why laptop is overheating
my laptop is overheating
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
3 Respuestas
Solución Elegida
Hi @jwamb ,
Here’s a link to the service manual for your laptop.
Scroll to the bottom of p.29 to view the necessary pre-requisite steps and then the procedures to remove the system fan so that you can clean it and the vents.
You may also use the opportunity when you have dis-assembled that laptop this far to remove/ replace the thermal paste that is covering the CPU, as the old application of paste has no doubt dried out and is not as effective. Be careful as you do this so as to not damage anything. As always with electronics be gentle. ;-)
Fue útil esta respuesta?
Puntuación 4
1 comentario:
More like don't even think about opening it until you get the repaste done with how complicated it is on this generation of E5 series. Get it over with since the motherboard needs to come out.
My E6 series isn't as horrible (bottom cover only), but you need to remove the heatsink to unbolt the fan, which in turn requires new thermal paste anyway.
- de
Go for a cleaning job of your complete laptop it will helpful in dealing with your laptop overheating issue
Puntuación 0
It is overheating because your cpu fan is not makeing enought airflow to cool your components and you cant really fix it only if you replace the fan or make sure the wires witch power the fan are conected well and thermal paste is enought to cover the cpu and the gpu
Puntuación 0
Añadir tu respuesta
georjo estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 20
Todo El Tiempo: 2,059
