Saltar al contenido principal
2.3L 4cil o 3.0L V6, 6ª generación
Why are my dash lights not working?
I have a 98 honda accord EX and my dash lights do not work properly (they don't turn on). I have tried to adjust the brightness switch, nothing. Their is an aftermarket sony deck that came with the car at the time of purchase. I've read that that may have caused the problem...
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
7 comentarios
Dash light and tall light dnt work but my brake light do work why
- de
My dashboard lights not coming on inside my 1999 Honda accord
- de
My Honda Accord euro 2004 dash light and tail light not working
- de
My dashlights stopped working and my SRS light is staying on now.
- de
Me too Angel kay Hewitt what did you do?
- de
Mostrar 2 comentarios más
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Here's a discussion on the same problem with someone who also added sound stuff:
http://honda-tech.com/showthread.php?t=2...
Fue útil esta respuesta?
Puntuación 3
Check the wire harnesses in where the passenger side fuse box is, on my car one of the plugs had a loose connection that was causing my dash lights and park lights not to function
Puntuación 2
2 comentarios:
Most Definitely a fuse or a loose wire in the fuse box.
- de
I will know for sure tomorrow and hopefully that can help you with your a car problem.
- de
With an aftermarket stereo you should check, I beleave if memory serves mo correctly, itsmthe Orenge wire. It's for the dimmer on the stereo. 9n mine it took out the Multiplex controller modual. I went past it and jumped 2mwires I now have dash lights. Pnly thing is , no more dimmer, the dash lights are on high all the time, I don't mind mine were a little too dim for me anyway ......Good Luck !!!!!!
Puntuación 0
Añadir tu respuesta
Oluseun estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 29
Todo El Tiempo: 36,874
