Introducción
Use this guide to replace the accessory antenna board in an Xbox Series X.
Before you begin, completely power down and unplug all cables from your console. Remember to follow general electrostatic discharge (ESD) safety procedures while repairing the console.
Qué necesitas
Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
Herramienta utilizada en este paso:Magnetic Project Mat$19.95
Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
Pry up the back panel to release it from the locking clips.
Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
One 10.5 mm pancake screw
Two 8.8 mm screws
Herramienta utilizada en este paso:Tweezers$4.99
Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
Use the flat end of a spudger to lift up on the locking tab holding the base to the shell.
Grip the base and rotate it counterclockwise to unlock it from the shell.
Remove the base.
Use a T8 Torx driver to remove the two 8.8 mm screws securing the optical drive's vibration isolator to the shell: one on the base and one on the top of the isolator.
Lift up the optical drive's vibration isolator to remove it.
Use a pair of blunt tweezers to grip the edges of the optical drive power connector and pull up to disconnect it from the optical drive.
Use your fingers to pull up and disconnect the data cable from the optical drive.
Grip the top edge of the optical drive and pull it out of its slot in the shell to remove it.
Use the flat end of a spudger to flip open the metal locking tab on the USB port ribbon cable.
Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
Use a T8 Torx driver to remove the three 7.4 mm screws securing the center chassis assembly to the shell.
Gently peel the taped USB port ribbon cable off of the heatsink.
Grip the center chassis and pull it towards the green fan grille at the top of the shell, uncoupling the guide pegs from the shell.
Lift out the center chassis assembly to remove it from the shell.
Use a T8 Torx driver to remove the three 9.6 mm screws securing the antenna board to the center chassis.
Grip the antenna board and pull it directly away from the center chassis to disconnect it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
8 personas más completaron esta guía.
4 comentarios
Had a Xbox Series X with a completely non-functional sync button, xbox light did not blink upon pressing it. Controllers or other Xbox wireless accessories did not work either. Replacing this board fixed that issue! In case anyone else runs into the same problem.
had exact same issue, replacing with this board fixed it for me also.
This was extremely well described. For me, however it did not solve my problem. I solved my controller connectivity and wifi issue simply by plugging in a powered external hard drive into the front USB of my Xbox Series X. It appears that possibly the power supply was not generating enough power and this little boost has sorted it. It only worked after I connected the external powered drive and then rebooted.
Great guide! I bought my first ever iFixit kit and followed this guide for my first true electronics repair. My Xbox Series X was sitting mostly unused for over two years because of this part failure and Microsoft quoted my $290+ for a repair. I was able to get things back up and running well within the hour timeframe.
