Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 17 guías que incluyen este paso.
Traduciendo paso 2
Paso 2
Use a pair of tweezers to pull up on the black plastic pull tab to disconnect the USB port cable.
- | [* black] Use a pair of |
+ | [* black] Use a pair of tweezers to pull up on the black plastic pull tab to disconnect the USB port cable. |
[* icon_caution] Pull only on the pull tab, not the cable itself. | |
- | [* icon_note] If the USB port cable feels adhered to the metal chassis, [guide|11677|apply an iOpener|new_window=true] or |
+ | [* icon_note] If the USB port cable feels adhered to the metal chassis, use an [guide|11677|apply an iOpener|new_window=true] or [guide|157348|hair dryer|new_window=true] to heat the cable. Depending on your model of Xbox, you may also need to slide an opening pick under the cable to separate the adhesive. |
