Huawei Mate 8 Display Replacement
Introducción
Ir al paso 1Use this guide to replace the defective display of your Huawei Mate 8.
Qué necesitas
Kits de reparación
Este kit contiene todas las piezas y herramientas necesarias para completar esta guía.
Partes
Herramientas
Ver más…
Remove the liquid indicator sticker.
Remove the Phillips #00 screw that holds down the metal shield.
Use a spudger to remove the metal shield.
Get a good grip on the pull tab near the power button and peel out the adhesive strip by steadily pulling at the tab in a flat angle.
Heat an iOpener and place it on the phone for about a minute to loosen the remaining adhesive.
Carefully insert the flat end of a spudger to separate any remaining adhesive at the top of the battery.
Remove the four Phillips #00 screws holding the daughterboard and loudspeaker to the phone.
Herramienta utilizada en este paso:Tweezers$4.99
Insert the flat end of a spudger under the loudspeaker at the gap on the left side.
Work the spudger under the loudspeaker to seperate it from the adhesive and remove the loudspeaker.
Use tweezers to take the vibration unit out of its housing.
9 personas más completaron esta guía.
