Saltar al contenido principal
HP EliteBook x360 830 G6 Battery Replacement
Clay Eickemeyer
Clay Eickemeyer y 5 otros contribuidores
Última actualización: April 5, 2024
15 - 30 minutos
Moderado
Introducción
Ir al paso 1
Use this guide to replace the battery in your HP EliteBook x360 830 G6.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Qué necesitas
Partes
Herramientas
Ver más…
  1. HP EliteBook x360 830 G6 Battery Replacement, Unfasten the back cover: paso 1, imagen 1 de 1
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
  2. HP EliteBook x360 830 G6 Battery Replacement, Release the clips: paso 2, imagen 1 de 2 HP EliteBook x360 830 G6 Battery Replacement, Release the clips: paso 2, imagen 2 de 2
    • Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • These clips will make an audible click when they release.
    • Repeat this process for the opposite corner.
  3. HP EliteBook x360 830 G6 Battery Replacement, Release the remaining clips: paso 3, imagen 1 de 2 HP EliteBook x360 830 G6 Battery Replacement, Release the remaining clips: paso 3, imagen 2 de 2
    • Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
    • Pry up to release the additional retaining clips.
  4. HP EliteBook x360 830 G6 Battery Replacement, Remove the back cover: paso 4, imagen 1 de 3 HP EliteBook x360 830 G6 Battery Replacement, Remove the back cover: paso 4, imagen 2 de 3 HP EliteBook x360 830 G6 Battery Replacement, Remove the back cover: paso 4, imagen 3 de 3
    • Grab the cover by the corners next to the hinges.
    • Swing the cover open and away from you.
    • If the back cover feels stuck to the chassis, use an opening pick to release remaining clips around the perimeter of the back cover.
    • Lift and remove the back cover from the laptop body.
  5. HP EliteBook x360 830 G6 Battery Replacement, Disconnect the battery: paso 5, imagen 1 de 3 HP EliteBook x360 830 G6 Battery Replacement, Disconnect the battery: paso 5, imagen 2 de 3 HP EliteBook x360 830 G6 Battery Replacement, Disconnect the battery: paso 5, imagen 3 de 3
    • Use the point of a spudger to push the sides of the battery connector out of its socket.
    • Push on alternate sides to "walk" the connector out.
  6. HP EliteBook x360 830 G6 Battery Replacement, Unfasten the battery: paso 6, imagen 1 de 1
    • Use your Phillips screwdriver to remove the five 4.2 mm-long screws securing the battery.
  7. HP EliteBook x360 830 G6 Battery Replacement, Remove the battery: paso 7, imagen 1 de 3 HP EliteBook x360 830 G6 Battery Replacement, Remove the battery: paso 7, imagen 2 de 3 HP EliteBook x360 830 G6 Battery Replacement, Remove the battery: paso 7, imagen 3 de 3
    • Pull the battery out from the retaining tabs at the front of the chassis.
    • Remove the battery.
Conclusión
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our HP EliteBook community for help.
Clay Eickemeyer
Miembro Desde 09/19/22
81,970 Reputación
455 Guías creadas
Equipo
Guide Team Miembro de Guide Team
Staff
Miembros de 9
11,434 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 11
Ultimos 30 días: 92
Todo El Tiempo: 2,603
