Saltar al contenido principal
Google Pixel 9 Pro XL Front Facing Camera Replacement
Spencer Day
Spencer Day y 2 otros contribuidores
Última actualización: October 17, 2024
1 - 2 horas
Moderado
Introducción
Ir al paso 1
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to replace the front-facing selfie camera in your Google Pixel 9 Pro XL.
If your front-facing camera's image looks fuzzy or blurry, or if the camera has stopped working entirely, it may be time to replace it.
You'll need replacement front camera and rear cover adhesives to complete this repair.
Note: Any repair can compromise the water resistance of your phone. Retaining water resistance after the repair will depend on how well you reapply the rear cover adhesive.
Qué necesitas
Kits de reparación
Este kit contiene todas las piezas y herramientas necesarias para completar esta guía.
Partes
Herramientas
Ver más…
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Google Pixel 9 Pro XL Front Facing Camera Replacement, Safety precautions: paso 1, imagen 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Safety precautions: paso 1, imagen 2 de 2
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
  2. Google Pixel 9 Pro XL Front Facing Camera Replacement, Adhesive information: paso 2, imagen 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Adhesive information: paso 2, imagen 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Adhesive information: paso 2, imagen 3 de 3
    • Adhesive secures the perimeter of the rear cover to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the rear cover to avoid damaging the internal components.
    • Measure 3 mm from the tip and mark your opening pick with a permanent marker. Alternatively, you can tape a coin to a pick 3 mm from the tip.
  3. Google Pixel 9 Pro XL Front Facing Camera Replacement, Apply a suction handle: paso 3, imagen 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Apply a suction handle: paso 3, imagen 2 de 2
    • Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
  4. Google Pixel 9 Pro XL Front Facing Camera Replacement, Insert an opening pick: paso 4, imagen 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Insert an opening pick: paso 4, imagen 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Insert an opening pick: paso 4, imagen 3 de 3
    • Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
    • Insert the tip of an opening pick in the gap.
  5. Google Pixel 9 Pro XL Front Facing Camera Replacement, Separate the rear cover adhesive: paso 5, imagen 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Separate the rear cover adhesive: paso 5, imagen 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Separate the rear cover adhesive: paso 5, imagen 3 de 3
    • Slide your opening along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
  6. Google Pixel 9 Pro XL Front Facing Camera Replacement: paso 6, imagen 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement: paso 6, imagen 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement: paso 6, imagen 3 de 3
    • Slide your opening pick up the left edge and along the top edge to separate the adhesive.
  7. Google Pixel 9 Pro XL Front Facing Camera Replacement: paso 7, imagen 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement: paso 7, imagen 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement: paso 7, imagen 3 de 3
    • Slide your pick down the right edge to separate the remaining adhesive.
  8. Google Pixel 9 Pro XL Front Facing Camera Replacement, Prop up the rear cover: paso 8, imagen 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Prop up the rear cover: paso 8, imagen 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Prop up the rear cover: paso 8, imagen 3 de 3
    • Don't try to fully remove the rear cover yet, as a ribbon cable on the right edge connects it to the phone.
    • Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
    • If you're having trouble, check the perimeter for any remaining adhesive and use your opening pick to separate it.
    • Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
  9. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the cable cover: paso 9, imagen 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the cable cover: paso 9, imagen 2 de 2
    • Use a Torx Plus 3IP screwdriver to remove the two 5.2 mm‑long screws securing the cable cover.
  10. Google Pixel 9 Pro XL Front Facing Camera Replacement: paso 10, imagen 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement: paso 10, imagen 2 de 2
    • Use tweezers or your fingers to remove the cable cover.
  11. Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the rear cover: paso 11, imagen 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the rear cover: paso 11, imagen 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the rear cover: paso 11, imagen 3 de 3
    • Use the point of a spudger to pry up and disconnect the rear cover press connector.
  12. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the rear cover: paso 12, imagen 1 de 1
    • Remove the rear cover.
    • During reassembly, follow this guide to apply new adhesive and install your back cover.
  13. Google Pixel 9 Pro XL Front Facing Camera Replacement, Peel up the cable cover tape: paso 13, imagen 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Peel up the cable cover tape: paso 13, imagen 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Peel up the cable cover tape: paso 13, imagen 3 de 3
    • Use the tip of a spudger and your fingers to peel up the piece of tape near the left edge of your phone, enough that you can access the bracket and screws underneath.
    • You can completely remove the tape if you want, but be sure to keep it for reassembly.
  14. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the cable cover: paso 14, imagen 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the cable cover: paso 14, imagen 2 de 2
    • Use a Torx Plus 3IP screwdriver to remove the two 5.2 mm‑long screws securing the wireless charging cable cover.
  15. Google Pixel 9 Pro XL Front Facing Camera Replacement: paso 15, imagen 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement: paso 15, imagen 2 de 2
    • Use tweezers or your fingers to remove the cover.
  16. Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the wireless charging assembly: paso 16, imagen 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the wireless charging assembly: paso 16, imagen 2 de 2
    • Use the tip of an opening pick to pry up and disconnect the wireless charging press‑connector.
  17. Google Pixel 9 Pro XL Front Facing Camera Replacement: paso 17, imagen 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement: paso 17, imagen 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement: paso 17, imagen 3 de 3
    • Use the point of a spudger to pry up and disconnect the ultra‑wideband press connector.
  18. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the wireless charging assembly screws: paso 18, imagen 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the wireless charging assembly screws: paso 18, imagen 2 de 2
    • Use a Torx Plus 3IP screwdriver to remove the two 2.2 mm‑long screw securing the wireless charging assembly.
  19. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the wireless charging assembly: paso 19, imagen 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the wireless charging assembly: paso 19, imagen 2 de 2
    • Remove the wireless charging assembly.
  20. Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the battery: paso 20, imagen 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the battery: paso 20, imagen 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the battery: paso 20, imagen 3 de 3
    • Use a spudger to pry up and disconnect the battery press connector.
  21. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave cover screw: paso 21, imagen 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave cover screw: paso 21, imagen 2 de 2
    • Use a Torx Plus 3IP screwdriver to remove the 5.2 mm‑long screw securing the mmWave antenna cover.
  22. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave cover: paso 22, imagen 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave cover: paso 22, imagen 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave cover: paso 22, imagen 3 de 3
    • A tight metal clip secures the bottom left corner of the mmWave antenna cover.
    • Insert the point of a spudger under the tab near the bottom left corner of the mmWave antenna cover.
    • Use your spudger to slide the cover to the right while prying up to unclip the cover.
  23. Google Pixel 9 Pro XL Front Facing Camera Replacement: paso 23, imagen 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement: paso 23, imagen 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement: paso 23, imagen 3 de 3
    • Gently pull the right edge of the cover towards the bottom of the phone and remove the cover.
    • During reassembly, insert the two tabs on the top corners under their recesses in the frame and push the cover down to clip it into place.
  24. Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the 5G mmWave antenna: paso 24, imagen 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the 5G mmWave antenna: paso 24, imagen 2 de 2
    • Use the point of a spudger to pry up and disconnect the mmWave antenna press connector from the top right corner of the logic board.
  25. Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the front facing camera: paso 25, imagen 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Disconnect the front facing camera: paso 25, imagen 2 de 2
    • Use the point of a spudger to pry up and disconnect the front facing camera press connector.
  26. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave screw: paso 26, imagen 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave screw: paso 26, imagen 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave screw: paso 26, imagen 3 de 3
    • Be very careful not to touch the cameras during this step. If you accidentally do, wipe them with a clean microfiber or lint‑free cloth.
    • Carefully hold the front facing camera cable out of the way so you can access the mmWave antenna screw.
    • Use a Torx Plus 3IP screwdriver to remove the 4.2 mm‑long screw securing the mmWave antenna.
  27. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave antenna: paso 27, imagen 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the 5G mmWave antenna: paso 27, imagen 2 de 2
    • Use tweezers or your fingers to remove the mmWave antenna.
    • During reassembly, make sure the mmWave antenna goes under the front facing camera cable.
  28. Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the front facing camera: paso 28, imagen 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the front facing camera: paso 28, imagen 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Remove the front facing camera: paso 28, imagen 3 de 3
    • Light adhesive secures the front facing camera in place.
    • Use the point of a spudger to lift the right edge of the front facing camera, separating its adhesive.
    • Use tweezers or your fingers to remove the camera.
  29. Google Pixel 9 Pro XL Front Facing Camera Replacement, Apply new front camera adhesive: paso 29, imagen 1 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Apply new front camera adhesive: paso 29, imagen 2 de 3 Google Pixel 9 Pro XL Front Facing Camera Replacement, Apply new front camera adhesive: paso 29, imagen 3 de 3
    • Use tweezers to remove the old front facing camera adhesive from the frame.
    • Remove the larger clear liner from the front facing camera adhesive.
    • Use tweezers to carefully place the adhesive into the front facing camera recess.
    • Use a spudger to press the adhesive into place, securing it to the frame.
    • Remove the remaining blue liner from the adhesive.
  30. Google Pixel 9 Pro XL Front Facing Camera Replacement, Install your replacement front camera: paso 30, imagen 1 de 2 Google Pixel 9 Pro XL Front Facing Camera Replacement, Install your replacement front camera: paso 30, imagen 2 de 2
    • Remove any protective caps or liners from your replacement front facing camera.
    • With the cable on the right edge, press the front facing camera into its recess to secure it with the adhesive.
Conclusión
To reassemble your device, follow these instructions in reverse order starting with this step.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Una persona más ha completado esta guía.
Spencer Day
Miembro Desde 09/14/22
94,645 Reputación
662 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
118 Miembros
19,425 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 37
Todo El Tiempo: 280
