Saltar al contenido principal
Índice
Wiki con Contribuciónes de Estudiantes
Esta wiki ha sido creada por un increíble grupo de estudiantes de nuestro programa educativo.
Failure to Charge
Even with battery power supplied, the computer does not retain charge.
Faulty Power Adapter
Check to see if your charging cord is plugged into both the outlet and the laptop. If the charging light does not appear next to the charging port, it is possible that you could need a new power adapter.
Faulty Battery
Make sure that the charging cord is plugged in completely. If the laptop only stays on while it is plugged in, that’s a sign that there may be an issue with your battery and that you may want to replace it. To properly replace the battery follow this guide.
Faulty Charging Port
Make sure that the charger is plugged into the laptop fully, There should be a light in the shape of a circle that starts to glow. If there is no light and the laptop is plugged in all the way, there could possibly be an issue with the charging port. You might need to clean the port or get it fixed.
Distorted or no Audio
There is no audio or audio is distorted
Detached/Loose audio jack
First you should test the speakers on the laptop and then test the speakers with the headphones plugged in. If the speakers sound normal from the laptop but cuts in and out through the headphones, that could be because you have faulty headphones or a faulty audio jack. If it is the headphones, you would need to get knew ones, if its the audio jack, you would have fix it.
Corrupted Speakers
If the audio through the speaker is distorted, then the sound driver could be corrupt. Search fo“Hp Support”. Click “Software and Drivers”. Then click the drop down for “Diagnostic tools” and select “Computer Diagnostic Tools”. Click the “Sound Issue” module and launch the diagnostic test to resolve the audio issue.
Keyboard Not Responding
Keys on the keyboard won’t respond or appear to be broken
Jammed Keys
If the key keeps getting stuck down and not returning to its normal state, there is the possibility that the area underneath it needs to be cleaned. In this case, remove the key and clean the area. After that, place the key back in place and it should function as usual.
Unresponsive Keys
If your keys are not performing its tasks when you tap them, it could be because they are clogged with something underneath it. In order to fix this, you would need to remove the key and make sure that it is clean underneath. If it is not, you would need to clean it and then snap the key back in place. The key should return back to normal functions after the cleaning.
Webcam Malfunction
You can hear the other person but you can't see them
Camera is Damaged
 If you encounter issues with video display or resolution, then search “HP Envy Webcam”. Click “HP PCs - Webcam Troubleshooting” If the video does not display for messaging apps then click the second drop down and follow the steps .If the webcam has low quality resolution then clock the sixth drop down and follow the steps.
Unresponsive Touch Screen
Display screen is discolored, blurry, or will not respond to touch
Damaged Screen
If your screen is cracked and not responsive anymore, this means the screen is damaged and needs to be replaced. To replace the screen follow this guide.
Calibration Errors
Open the Start Menu. Select the Calibrate button, and if you are asked to authorize the process with admin privileges, authorize it. Follow the instructions given.
Dirty Screen
If your screen is not responding, a possible reason is because the screen needs to be cleaned. You can take a hand towel or wipe and clean the screen of. Make sure there are no smudges left on the screen. After this, your touch screen should preform its normal actions.
Un comentario
Non responsive keyboard in OS but works in BIOS could be Intel(R) Integrated Sensor. Disable driver and restart and might work again
Carlos - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 395
