Saltar al contenido principal
Anunciada en octubre de 2013, la Nikon D5300 es una DSLR de nivel de entrada superior con un sensor de tamaño DX de 24Mp.
Preguntas 20 Ver todo
My SD card got stuck inside!🤧
Pls someone help. I was just putting on some old sd cards into my nikon for no reason until i could not pull one out from the reader. I tried to reinsert and to eject it out but it wont come out from the slot. Pls someone help, i dont want my parents to find this out.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
If you successfully inserted and removed other SD cards, then you either inserted this one backwards and forced it in or it may have a label on it causing it to wedge in.
Best advice - show it to you parents and have them figure it out and take the hit. Otherwise, you are likely to cause more damage and who knows how many years it will take you to pay for a new camera.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
I got it fixed by myself🥳. I saw some Youtube videos on how to remove the sd card card and they said to use a paper cutter. Since my paper cutter did not work I used a nail filer to take the sd card out and it worked. By the way , thanks for the help bill. Now I am scared whether I should put the current sd card in. Well problems solved I guess🙂🥳
- de
Añadir tu respuesta
Joachim Dilip estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 15
