Saltar al contenido principal
La Nikon Coolpix L20 es una cámara digital compacta producida como parte de la línea Coolpix de Nikon.
Preguntas 9 Ver todo
Not turning on and I checked the fuse. 0 resistance.
My camera wont turn on and makes a clicking noise while it has batteries In it. I checked the fuse as you mentioned in another question and that did not work. You mentioned a D20-D20 issue? What would be the fix for that.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario
@ethanelphick not sure what you mean by D20-D20 issue. Also, You mentioned you checked the fuses but "that did not work" Does that mean you've checked the fuses and they have continuity?
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi Ethan,
I don't have answers for you, but your question was migrated from being an answer on another question to being its own question. As such, something's getting lost in the translation so I was going to try to fill in the blanks.
First off, the original post is here.
It’s not turning on - Nikon Coolpix L20 - iFixit
As suggested by @oldturkey03, I see you've checked the fuse and according to your test it's good. It appears oldturkey03 was referring to a DC-DC board, not a D20-D20 thing. Again I'm not familiar with your camera, but generally a DC-DC board is one whose job is to convert one DC voltage into a different voltage. For example your batteries might be providing 3 volts to the camera but there could be electronics in there that need, say 1.8 volts and 5 volts. The DC-DC board converts that 3 volt power to the other voltages needed to run the camera. Obviously if that board has died then it won't be supplying power to the rest of the camera that needs it, which is what oldturkey03 was suggesting.
However, I'm going to have to leave it up to him to elaborate on where that board is and/or how to test it.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Ethan Elphick estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 41
