Saltar al contenido principal
La Nikon Coolpix L20 es una cámara digital compacta producida como parte de la línea Coolpix de Nikon.
Preguntas 9 Ver todo
It’s not turning on
My camera stop turning on even though it is charged
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
@luchangtzudir going with the assumption that your battery is good and working and everything else is installed as is, I would suggest that you check the fuse on the main board. F1 is the power fuse and if that fuse has blown, the power can't be turned on. The fuse is a 32V 2A SMD fuse and you just need a multimeter and check the fuse for continuity.
If that should be okay, then you most likely have an issue with the DC-DC board. It's a bit tougher to fix ;-)
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Luchang Tzudir estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 19
Todo El Tiempo: 277
