My PC is acting weird and keeps turning off
For some reason, my Dell Dimension 3000 is acting VERY buggy ever since I tried to replace the CMOS battery(btw I confirmed it isn't the battery)
  • The PC keeps automatically turning off, most of the time staying on for less than a second.
  • If the PC manages to get on for a decent amount of time, I might see a error such as "Previous startup attempt failed at checkpoint [random every time]" or "Previous startup attempt failed due to thermal event"
  • Speaking of the thermal events, one time I saw that error, opened up the PC and found out the CPU was stone cold.
  • Sometimes it shows me a glitched out screen(the pc uses integrated graphics)
Here are pictures of the internals:
And my ports:
  • AC power cord
  • VGA cable(integrated graphics)
  • Keyboard and mouse(High-speed USB ports)
UPDATE #1: I tried turning it on and it succeded:
  • Here's a picture of the error screen(I had unplugged the usb keyboard and mouse for troubleshooting purposes)
  • The screen glitched out right after the error screen and then shut down:
  • I tried a few more startup attempts and now it's essentially thermal events(CPU is still cold)
UPDATE #2:
  • The issue went away! Hopefully it stays that way. I'll have to see.
UPDATE #3:
  • It's back and worse than ever! First time I booted it up, it showed me only an amber light. All diagnostic lights off, no video output, and no beep codes.
  • The regular issue came back after that.
  • I suspect the PC may only work after it warms up.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
4 comentarios:
Hi @daneelliottd532,
When it starts check that the CPU fan is working OK and is dust free etc.
Thermal events are heat related so hopefully it isn't a faulty CPU
- de
I checked the fan and it seems to have adequate airflow. I might try another CPU.
- de
@jayeff If I keep trying to turn it on, it will work normally again. Maybe it works only after it warms up?
- de
@daneelliottd532 the second images looks like your computer either has a CPU or a GPU error. Can you just boot into the BIOS not your OS and is that relatively stable?
- de
Agregar un comentario
