Saltar al contenido principal
El teléfono inteligente de la tercera generación de Google con marca Pixel y su primer teléfono con muescas. Viene con una pantalla QHD + OLED de 6.3 "y 64 o 128 GB de almacenamiento. Disponible en Nearly White, Just Black, o Not Pink.
Preguntas 20 Ver todo
Screen unresponsive after battery replacement.
After replacing my battery yesterday, the screen worked fine for 1–2 hours. Then the touch functionality stopped working in the top third of the screen. Within 30 minutes, there was no touch functionality except for the bottom 5 mm of the screen. I left it overnight, and now the screen flashed a few colors and won't turn on. I assume the phone is on since it vibrates when I hold the power button. After opening it up again, I checked the connectors for display, battery, buttons and coil, which were correctly seated. The display is still black.
Is the only option a replacement screen, or is there something else I can try before committing to that option (200€).
EDIT:
For some reason, the screen now flashes on dimly and the shuts off quickly while a white line appears in the top third of the screen when I press the lock button.
EDIT 2:
After turning off and on again, the display turned on for a split second showing the boot process, but faded to black right away. I can make out a faint Outline of the google logo afterwards, but nothing after. I'm starting to suspect that the backlight isn't working...
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
It seems that IPA seeped into the display somewhere while replacing the battery, causing these issues. After letting it sit a while (sometimes warming it up), the display works again. Touch is still a bit spotty and it flickers sometimes, but I hope this will resolve itself once all the IPA evaporates.
Fue útil esta respuesta?
Puntuación 0
Double check the screen connector
Puntuación 0
2 comentarios:
Just did. Have opened the phone and unplugged then replugged the screen twice now, no change.
- de
@jaundice then you'll need to replace the display.
- de
Añadir tu respuesta
Jaundice estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 25
Todo El Tiempo: 277
