Saltar al contenido principal
El Manscaped Lawnmower 3.0 es un cortapelos eléctrico e inalámbrico resistente al agua para el vello corporal.
Razor blinks red after full charge.
I charged my razor to a solid green light over the course of a day and a half, went to go use it and it started blinking red immediately after turning it on. I can't say it felt weaker than normal, either. Is the battery going? Any recommendations for a fix, or should I just get the new one?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi @kyithios
Try replacing the battery and check if that resolves the problem.
Here are two videos that will help.
This video shows how to open the shaver and this video shows the battery etc.
You will need a soldering iron and tools to do the wortk. Also take note of which end of the battery is the +ve end before removing the original battery so that you replace the new one exactly the same way.
The battery model information is printed on the battery. Search online for (insert battery model) with solder tabs to find suppliers that suit you best. Having solder tabs already there makes it easier to solder on the new battery as you don't have to apply as much heat as you would for batteries that don't have them and it could be dangerous if the battery got too hot when trying to solder it on. (Unfortunately I can't quite make out what is on the battery as it is too blurry even when zoomed in).
The razor is supposedly waterproof but once opened and repaired it most probably won't be anymore. Just something to be aware of.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Rubens Garcia estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 30
Todo El Tiempo: 381
