Why is my tv screen getting black
On my TV screen coming a thick black belt and on this belt coming a white thine line
Es esta una buena pregunta?
Obtén acceso rápido a guías, piezas y respuestas para tus dispositivos
@akshaypardeshi first we need to know the exact model of your TV. Next we need to see what your screen shows you. Next we need to know if you still have sound on your TV. This could be a bad T-con board, bad main board or even a bad panel. REmove the back from your TV after disconnecting the power cable. Remove the ribbon cables (one-by-one) and check those for tears and corrosion. Reseat them. After that you could check some voltages on your board but we need to see exactly what boards you have in your TV. Post some good pictures of your boards as well. MY prime suspect on this is the main board. followed by a failed source driver ribbon (LCD driver board)
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 61
