Saltar al contenido principal
Lanzado en 2014, identificado por el número de modelo BDP-S7200.
Preguntas 1 Ver todo
Philips HTB3520/94, POWER OFF AFTER 30 MIN.
My philips home theater model no. HTB3520/94 turns power off, no indicator, after 30 minutes...
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
@sunildeshmukh first check your settings to rule out that this is caused by the timer
Energy saving settings
  1. Press (Home).
  2. Select (Setup), and then press OK .
  3. Select (Preference), and then press OK.
  4. Press the Navigation buttons and OK to select and change:
  5. (Screen saver) : Switch the home theater to screen saver mode after 10 minutes of inactivity.
  6. (Auto standby): Switch the home theater to standby after 30 minutes of inactivity. This timer works only when a disc or USB play is paused or stopped.
  7. (Sleep timer) : Set the duration of the sleep timer so that the home theater is switched to standby after the specified period
Fue útil esta respuesta?
Puntuación 0
6 comentarios:
It's power cut off power, no standby indicator, no light 🚦 indicator, it's off after 30 min or plus or minus 10 min. In working condition... Means it's power supply output to audio is correct but cut off may be heatsink not support...my opinion... Sleep mode what you said is not set by me... Or if it is working, then it should be working in ideal not in working means when my system is working or songs are playing continuously... Hope i tried to explain is right....
Pl correct me if I'm wrong...
- de
Anyway thanks for your effort to read and provide me the solution... 🙏👍🏻😊
- de
Meanwhile I replace the HTR of heatsink still problem remain same... It's power cut off after 30, 40min...
- de
Pl. Suggest any other solution...
- de
@sunildeshmukh That is good. At least we now know that this is not a settings issue. Let's see if we can determine what cuts the power. How long does it take before you can turn it back on? Few minutes or immediately?
- de
Mostrar 1 comentario más
Añadir tu respuesta
Sunil estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 4
Todo El Tiempo: 143
