Saltar al contenido principal
Anunciado el 13 de octubre de 2020, el iPhone 12 mini es una versión más pequeña del iPhone 12 de Apple. Cuenta con una pantalla OLED de 5,4 pulgadas, un procesador A14 Bionic y dos cámaras traseras.
iPhone 12 mini black screen
i have an iphone 12 mini the screen is black. However when i place it on a wireless charger it gives a charging beep but the screen remain black. What could be the problem? is it the screen or the battery not charging??
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
4 comentarios
It probably died and you have to get a new one.
- de
thank you. U mean new battery not new phone?
- de
New batterys
- de
And if that doesn't work you might have to buy a new phone.
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
@sirneilsirneil try seeing if it will connect to itunes, it could possibly be in dfu mode
Fue útil esta respuesta?
Puntuación 1
I'm going to disagree with @liljk; there's nothing to indicate a bad battery at this point. The fact that you get a normal reaction when setting it on a wireless charger says that the phone is running. I'd want to do some investigation first, but in situations like you're describing it's generally a screen problem.
First thing to do is try plugging it into a computer and see if it's recognized. If possible, try doing a full restore of the phone's firmware to try and rule out the possibility that it's a software issue rather than hardware.
Worst case in my opinion is you have to replace the screen. Here's the iFixit guide do to that.
Reemplazo de la pantalla del iPhone 12 mini
Puntuación 1
Añadir tu respuesta
Sir Neil (Sirneil) estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 291
