Battery charger not working
Es esta una buena pregunta?
Obtén acceso rápido a guías, piezas y respuestas para tus dispositivos
Gordon Young that camera does not charge the battery. You will need a separate battery charger. Make sure that your battery is still capable of holding a charge. so you need to check your battery chargers in-voltage, and your out-voltage. If those are okay, I recommend to replace the battery.
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 98
Hi,
If the charger is used with a wall plug power adapter, have you checked that there is 8.4V DC on the output cable plug of the adapter? example to show specifications of the adapter(s)
What have you tried?
- de jayeff
