Saltar al contenido principal
Lanzada a principios de 2015, la Canon PowerShot SX530 HS es una cámara con súper zoom habilitada para Wi-Fi. Esta cámara pesa poco menos de una libra. Identificada por el número de modelo pc2200.
Preguntas 18 Ver todo
Camera's shutter does not close when taking a picture
Camera is actually Canon Powershot SX430 IS but could not find it listed in the site.
Usually whenever I take a picture, the camera would produce a snap sound which I thought would be the camera's shutter. However, recently the camera would not close the shutter when taking pictures as there is no 'snap' sound produce after pressing the shutter button, causing the pictures to appear overexposed on the camera. Everything on the exterior of the camera seems fine. Could the shutter be jammed?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
2 comentarios:
Have you found any fix for the issue?
- de
My camera's model no. is Canon SX430IS
- de
Agregar un comentario
2 Respuestas
Hi @zerot,
Don't know about the shutter's mechanical operation, have you tried all operating "modes" to see if the problem occurred in each mode in case it is a software problem only in one mode.
Try resetting the camera and check if that resolves the problem see p.109 the user manual.
The shutter "sound" volume is adjustable in Settings, check that it hasn't been turned off - see p.103 in the manual
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
Hi there,
I have tried operating in all the different modes and resetting to default settings but still the shutter would not close with the pictures appearing bright and overexposed. And no, I am not referring to the sounds from the camera's speaker as I have muted the sounds ever since I first used it.
- de
I have the same problem. Were you able to fix it? The problem for me was, when I click photo the shutter does not close. It remains open.
- de
Reasons range from mechanical faults to software. First check if it is adequately charged because this can cause mechanical issues. Also check if there is any obstruction caused by dirt, sand, debris etc.
If that's ok, then check if any software needs to be updated and if that doesn't work, reset to factory settings.
If nothing works and your warranty is still valid, return the %#*@ thing.
Puntuación 0
Añadir tu respuesta
wildan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 196
