Saltar al contenido principal
Lanzado en Septiembre 16, 2016. Modelos 1660, 1778. Disponible en GSM o CDMA / 32, 128, o 256 GB / Oro Rosa, Oro, Plata, Negro Mate y Negro Brillante.
Preguntas 22 Ver todo
Wifi greyed-out even after replacing antenna
Hello everyone,
I just bought a second hand iPhone 7 knowing that its wifi would not work but since I had another iPhone 7 which wifi is working properly I thought to switch the pieces (speaker/wifi antenna).
However, the wifi remains greyed out, bluetooth works. What can I do to fix this?
Thank you :)
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
If Wi-Fi is greyed out you have a board problem and not a parts problem. You will need to replace or re-ball the Wi-Fi IC. If you replace it you will have to unbind its Address from the NAND. This repair will require the correct equipment and experience in microsoldering.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Hello,
Thank you very much !
I'll dig into that NAND problem as well as microsoldering which I know nothing about ahah.
Thanks again !
- de
Añadir tu respuesta
KasDing estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 192
