Saltar al contenido principal
iFixit utiliza cookies para mejorar la funcionalidad del sitio, analizar el tráfico y personalizar los anuncios. Al utilizar nuestro sitio, aceptas nuestro uso de cookies y nuestra Política de privacidad.
Lanzada a principios de 2015, la Canon PowerShot SX530 HS es una cámara con súper zoom habilitada para Wi-Fi. Esta cámara pesa poco menos de una libra. Identificada por el número de modelo pc2200.
Problem with screen image through the lens
Hello, yesterday I was making the shooting, and while I was taking a picture with using the zoom, the picture on the screen through lense suddenly became very ruffle while shooting, with many bright strips, colors became distorted, an image turned into like on a very old TV with ripples. The pictures done look the same in the gallery plus when I turn on the camera I see the same effect on the screen through the lense. I was very gentle with my camera, I don’t know why It happened. Previousy the image was very clear like I look through the clear glasses. Please, If you know what to do, help me with this. Thank you in advance.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios:
Hi,
What happens if you take some pictures and download them to a computer and look at them there. Are they clear or also distorted?
- de
@jayeff Hello, when I download them to the computer they are clear and normal
- de
Agregar un comentario
1 Respuesta
Hi,
It seems as though the camera’s LCD display either has a loose cable connection or it is faulty.
Here’s the ifixit Canon PowerShot SX530 HS Display Replacement guide.
This shows how to open the camera and check that the LCD flex cable connection to the motherboard is securely connected, (see image at Step.10). If it secure then as a DIY repair all you can do is to replace the LCD display and check if it now works OK, because if it is faulty it cannot be repaired, it has to be replaced.
Search online for Canon PowerShot SX530 HS Camera LCD Display Screen to find suppliers that suit you.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Nina Nikolayeva estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 272
