Saltar al contenido principal
Lanzado el 22 de septiembre de 2017. Modelo A1864, A1897. Disponible como GSM o CDMA / 64 o 256 GB / oro, plata y gris espacio.
Preguntas 20 Ver todo
Will a 7 battery plug into an 8 plus?
I’ve been asked to look at an iPhone 8 Plus that won’t charge or turn on. Checking the battery I assume is the first course of action. But, the only spare battery I have kicking around is out of an iPhone 7. Are the connectors the same? Would I be able to plug the 7 battery into the 8+ just to test it?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
The battery connector is different so unfortunately they can't be plugged into a different model.
First course of action for me is to check if the charging cable is plugging in snugly. If not with a gap I then clean the charging socket of any foreign material or gunk and see if it charges.
A USB ammeter (which can be bought relatively cheap on eBay) will help to diagnose if charging socket is working at all.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Jenn estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 72
