Saltar al contenido principal
The Huawei Honor 8 is an Android smartphone released in 2016 that features a 5.2-inch 1080p display, 4GB of RAM, dual 12MP camera sensors, a fingerprint sensor, and a USB Type-C port. Model : FRD-L04.
Preguntas 20 Ver todo
Screen Replacement ( To Glue Screen And Frame)
Can I use any Adhesive Gum like Fevicol to Glue my Screen and Frame Or should I use any particular Glue like B-7000 ?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
@pro_gamer this “The best way to secure the new screen is with a sheet of custom-cut double-sided tape. Apply the tape to the back of the screen, then carefully feed the display cable through the frame. Align the screen and press it into place.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.” from Reemplazo del LCD y digitalizador del Huawei Honor 8here. Any other glue will be a PITA to remove if you need to replace it again.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
how do you replace the new screen, with band or glue
- de
Only use adhesib t8000 glue or gum.My
experience about 10 years its good.
Puntuación 0
Añadir tu respuesta
Anish Kusunuri estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 644
