Saltar al contenido principal
Lanzado en Septiembre 16, 2016. Modelos 1660, 1778. Disponible en GSM o CDMA / 32, 128, o 256 GB / Oro Rosa, Oro, Plata, Negro Mate y Negro Brillante.
Preguntas 22 Ver todo
lost lower connector screw post
I was replacing a phone screen in accordance with the Reemplazo pantalla de un iPhone 7 tutorial. Apparently, during step 13 and 14 the screw post that the top 1.2mm screw screws into on the main board came loose. When I went to screw the lower connector bracket back in after the screen replacement the top screw would not install. Does anyone know if the iPhone 7 Screw Set contains these posts? It’s hard to tell from the product photo.
Imagen de Replace any stripped or missing screws in your smartphone with this complete set of screws. This set is compatible with an iPhone 7.
Producto
iPhone 7 Screw Set
$9.99
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
What you're looking for is called a standoff screw, if that helps any. Also it's not great but you should be able to use the phone just fine without it. Use an organizer next time to keep better tab of your parts.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Stephen Garden estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 93
