Replacement part for my HP Envy
I would like to find out if possible where can I get a replacement part for my HP envy 360 m6 earphone Jack thanks in advance
Es esta una buena pregunta?
Obtén acceso rápido a guías, piezas y respuestas para tus dispositivos
Hi @geomichi ,
Here is a link to the service manual for your laptop , taken from this HP webpage.
Scroll to p.38 to view the necessary pre-requisite steps and then the procedure to remove the connector board. Also on p.38 you'll find the spare part number for the board 856792-001. (and also the cable part number 856801-001 if it is necessary).
But on p.16 it shows that the connector board part number (#9) is 856808-001. Bit confusing.
Search online using the part number only in the search box of your browser, to find suppliers of the replacement board.
Both board part numbers seem to point to the same board when searching online.
Check what number is stamped on the board in your laptop, if any.
Hopefully this is of some help.
Fue útil esta respuesta?
Thank you very much it's appreciated I'll search and see if it can slove my problem again thanks.
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 561
2 comentarios
Hi @geomichi ,
What is the full model number of your laptop?
- de jayeff
It's the HP Envy 360 m6-ar004dx
- de Nicholas22
