Saltar al contenido principal
Modelo de principios de 2011, A1278 /2.3 GHz i5 o 2.7 GHz con procesador i7.
Preguntas 20 Ver todo
boot fail, fan spin, black display
fixing for a friends
he say to me that is dropped and after gone on sleep, never come back and won't boot anymore.
when u press power button, stars with fan spin and black screen and no more just gradual fan acceleration
i tried:
other magsafe = same
external monitor = same
i try with no ram = no beep
no battery= same
no hd = same
im on 99% logic board issue (seems like the classical gpu failure, but strange it was dropped..)
any suggestions are appreciate
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
It's not passing the initial POST checks if it is not beeping without RAM in. Check all the power rails to ensure they are present, especially ppvcore_s0_cpu.
These are usually the worst of the bunch to solve, and is very likely to be CPU related. Good luck :)
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
thanks Reece i check the back, i found some part little oxidised, i clean and still the same... to much for me try fix this board now...but thank you!
- de
Where the oxidation was, check for burnt pins on components, this is likely what was causing it (but this is now logic board repair, so take it to someone who does this if you are not comfortable doing this)
- de
Check pp1v5 and 1v5_GPU_REG - if it is a gpu panic, than u just have to replace the cap C9560
Puntuación 0
Añadir tu respuesta
lapo estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 299
