Saltar al contenido principal
Esta es un portátil de 35.70 cm (L) x 25.70 cm (W) x 2.54 cm (min H) / 3.96 cm (max H), la unidad pesa 6.6 lbs. Fue lanzado en 2006 y viene de serie con un disco duro de 80 GB.
Preguntas 6 Ver todo
Why does my cooling fan run so loud?
Every time I turn my computer on the cooling fan automatically runs very loud. It doesn't matter if there are no programs running or if I am streaming movies from the internet. I feel like the fan is going to blow up if this continues.
I have purchased a cooling base for my computer but it is still running hot. Do I need to use compressed air?
Please help before my computer explodes!!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
It sounds like there may be dust clogging the CPU or the fan itself, I'd recommend taking a look inside if you are able to
Fue útil esta respuesta?
Puntuación 0
If your fan seems to be running slower than usual, or even making louder noises then you should check the fan to see if it is clear from any dust or debris. If there is dust then get a can of compressed air and and clear it out.
Here is a link to our troubleshooting age regarding this problem: HP Compaq Presario V6000
Puntuación 0
Añadir tu respuesta
PJ Andress estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 1,053
