Saltar al contenido principal
The HP Envy 15 x360 is a laptop-tablet hybrid that can be identified by the model number 15-Uxxxxx.
Preguntas 9 Ver todo
My computer only works while the charger is pluged in.
I can only get my computer to work if I have it plugged in. Do I need to replace the battery?
Es esta una buena pregunta?
Puntuación 37
27 comentarios
My hp labtop is still shutting off after I unplugged it
- de
Its "laptop". Not labtop.
- de
@colemanrobert956 Mine is doing the same thing idk how to fix it
- de
same here! mine is doing the same thing only NOW the battery percentage is going down 1% per day. when unplugged it powers down right away. I assumed it was the battery. I dont even know how much a battery costs. if they are $50 like a cell phone i am SCREWED!!
- de
New battery in my ASU’s laptop but still only works on mains help please
- de
Mostrar 22 comentarios más
Agregar un comentario
7 Respuestas
Solución Elegida
Yes you will need to replace the battery. Since you are able to use your laptop when it is plugged-in, it is a great indicator that your charger adapter is not the issue. Make absolutely sure your computer is turned off. Remove the back cover of the laptop by unscrewing the screws and gently lifting the cover up. Locate the battery which is usually a relatively large rectangular shape device and replace it with a known working one. If this does not work, there might be an issue with the actual wires inside the laptop. If that is the case you will need to either send it back or see if a local electronic store can do something with it.
Fue útil esta respuesta?
Puntuación 30
7 comentarios:
It's not turning on when pugged in
- de
Thank you so much Sam- this seems to have worked. Battery was new supposedly “non” removable but where there’s a will….
- de
Even though battery is replaced with new one still issue persisting.
- de
Can anyone help me with the solution, do the needful
- de
my laptop is working only when i plugged in supply, and i bought a new charger even though my laptop is working only when i plugged in
- de
Mostrar 2 comentarios más
Respuesta Más Útil
Before you decide to give up on your battery and get a new one, there might be a chance that you finished using up every last ounce of energy in your battery and it didn't get time to charge again :)
Your laptop generally tries to charge the battery + run on power when it's connected to a power adapter. What's happening now is, the battery is not getting charged (actually, it's not getting detected) and your laptop thinks there's no battery and is simply running on power.
A new battery will of course have some charge and your laptop will be very happy with it and keeping charging it.
This is the 3rd time I'm writing this instruction today:
> Remove the battery and kill the static energy in your laptop by holding down the power button for 20 seconds.
> With the battery still removed, plug in the adapter and turn on the power.
> Your laptop starts working now.
> Now here's the tricky part - Insert the battery 'after' you've powered on the laptop. Now your laptop will detect the battery and start charging it.
Hope this helps! :)
Puntuación 33
37 comentarios:
Thank you genius!
- de
I have the same problem but the battery is not removable how can this be fixed? Can u please send me an email to get the answer asap thank u dlrs1009@yahoo.com.mx
- de
Works like a charm
- de
I really hope it works, giving it a try now. Thanks.
- de
I Tried but it still showing the charger is plugged in but not charging
- de
Mostrar 32 comentarios más
That would be the best guess. It is possible that there is another board failure preventing the battery from receiving the charge but a bad batter is the most likely failure here.
Puntuación 5
1 comentario:
Whenever I plug my laptop it displays battery 100% and the moment I unplug it shows battery low and go off.
- de
Hi i would recommend getting a new battery or try taking the battery out and putting in back in again
Puntuación 4
1 comentario:
Hi, My laptop shows an alert message to change the battery. But I'm in a situation where I cannot go to the service center now. How long will I be able to use the laptop without battery? In a only plugged-in mode? Now my laptop works only when connected to power supply.
Is it healthy to use it that way?
- de
Hi @mrfleming07,
Assuming that you have Win 10 installed, create a Win 10 battery report just to check that the new battery is OK first.
Puntuación 1
Replaced the battery and did everything suggested. Problem was fixed not by putting a new battery, nor inserting it while plugged and all that. I had to do a hot re-set on Windows losing many settings and programs. Problem solved? Yes, but today after a week working fine, it started doing the same thing!! Digging into this, I suspect a Windows update. When resetting windows, it tries to download updates, and one of these screws the battery issue, as reported by somebody on another forum. Asus techs have no idea why or what to do. A bummer.
Puntuación 1
In my case. I just replaced with a new battery. I let the battery charge to 100%… yes, the battery was able to chargeall the way with the power cord connected. BUT. I still need the power cord connected to turn onn the laptop. It will not turn on with just the battery connected. ??????
Puntuación 1
4 comentarios:
your case same with mine, my laptop still need power cord to turn on. how your laptop now ,any solutions
- de
My laptop has a problem as it it turned on when connected with power supply and when it turned on it can be used after removing supply. Can any one help me to fix this problem
- de
Have a HP 17z-cs000 and it is also only booting up with power cord plugged in, then once booted up it runs fine on battery without power cord. I am getting a CMOS Checksum error when it boots but have not had issues with date or time being incorrect. Not sure what steps to take next...may try resetting CMOS to factory and see if that helps...other than that ???? no idea!
- de
Joanne Johnson i have same problem, did you find any solution? Please let me know
- de
Añadir tu respuesta
James estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 43
Todo El Tiempo: 207,873
