Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La Canon PowerShot SD960 IS es una cámara digital de 12.1 MP con zoom óptico estabilizado de imagen de gran angular 4x y LCD de 2.8 pulgadas, fabricada por Canon en 2009.
Why do I get the "lens error restart camera" message?
When I turn on my camera I get a message that says "lens error restart camera" and the lens won't open. How can I fix this?
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
Try restarting the camera. If this doesn't resolve the issue grit or other physical obstruction may be blocking the shutter. Use compressed air or a hair dryer on the cool setting to clear the obstruction. If this doesn't resolve the issue or if there is damage to the lens, replace the lens. Also check out the full Troubleshooting Guide.
Fue útil esta respuesta?
Puntuación 1
First try to restart your camera. If the error continues something may be blocking the shutter and is keeping it from closing. Take canned air and attempt to blow the derbies free. If you do not have canned air you can use a blow dryer or just blow on the lens really hard. If this doesn't work you will most likely have to replace the lens.
Puntuación 0
Añadir tu respuesta
Kacy Ewing estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 22
Todo El Tiempo: 920
