Saltar al contenido principal
iFixit utiliza cookies para mejorar la funcionalidad del sitio, analizar el tráfico y personalizar los anuncios. Al utilizar nuestro sitio, aceptas nuestro uso de cookies y nuestra Política de privacidad.
ignition switch wiring diagram color codes
what are the wiring color codes of ignition switch
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
3 Respuestas
Solución Elegida
Peter, You can find your wiring schematics at the sight attached and download free.
http://www.revbase.com/BBBMotor/Wd
Fue útil esta respuesta?
Puntuación 2
Peter Celdran, not quite sure what you are looking for but start with this
You definitely have 3B- Yellow, 2B- White and 2L-Black. If you post some images of what you are looking at, we might narrow it down. Use this guide for that.
Puntuación 0
this is the harness I just need to know which one is the battery wires and which one is the ignition wires
Puntuación 0
1 comentario:
@bonnie88229 looks like Black/Yellow and Black/White for the ignition. White should be battery but we need to know the exact year, model and engine size to make sure. Use a test light or meter on each wire. You should be able to get the battery + which should have power at all times.
- de
Añadir tu respuesta
Peter Celdran estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 26
Ultimos 30 días: 96
Todo El Tiempo: 11,173
