Saltar al contenido principal
Una revisión de la PSP 300x original, lanzada en 2010. La reparación es igual de fácil.
Preguntas 10 Ver todo
Psp 300x Backlight Fuse
Hi Guys!
I have my old PSP 3001, I drop it on the floor. Still turn On and Off, but with out image...
I replacentment the LCD, but still not working.
So I found out that is a BACKLIGHT FUSE,
Please some one tell me
"WHERE IS THE BACKLIGHT FUSE"?
I am tired to find out and get no result!
Thanks all guys who read and help!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
There is only a backlight fuse. There is no screen fuse. There is either a problem with the screen, or one of the components on the motherboard. Probably the IC that is in charge of video.
Fue útil esta respuesta?
Puntuación 0
Try checking component ic4104. That's the backlight driver and is located in the 11,C quadrant of side A on a TA-085 v1 board. The part number is TB62752BFUG. Test each connected capacitor to ground in continuity mode with a basic multimeter for a short. If one or more of the capacitors are shorted remove those and check the pads where the capacitors were. If there's still a short on both pads where the capacitors were then put back the original ones. Odds are if there's a short to ground but doesn't go away when you remove the capacitors then TB62752BFUG needs to be replaced.
PSP 2k Schematics (~95% 3k)
https://gamingdoc.org/technical-document...
TB62752BFUG Datasheet
https://www.mouser.com/datasheet/2/408/T...
Puntuación 0
Añadir tu respuesta
Josemar Pereira estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 20
Todo El Tiempo: 541
