Saltar al contenido principal
Consulta estas guías para obtener información sobre la reparación y el desmontaje de tu máquina de coser.
Preguntas 20 Ver todo
Bernina 830 service manual
Zigzag not working. Need a service manual. If anyone has one. PDF form would be great.
Es esta una buena pregunta?
Puntuación 3
4 comentarios
I'm having trouble with the bobbin tension. Any suggestions?
- de
Hi @nannamarg ,
This link may be of some help. See 2nd post down.
https://thequiltshow.com/forum/bernina-c...
- de
I have just bought a nearly new but quite old Bernina Record sewing machine, but the clutch release wheel that you release to load the bobbin will not release, will it be ok to use a pair of grips to release it, or is the some other way to release it?
- de
I filled a bobbin with thread and now the knurled screw on the hand wheel will not re tighten. Can someone help with this?
- de
Agregar un comentario
3 Respuestas
Solución Elegida
Hey Cheryl, I found a link to the manual of your specific model here and the user manual here. The threadguide/lubricating unit pdf can be found here. You can check out the firmware details here.
-Let me know how it goes.
Fue útil esta respuesta?
Puntuación 1
3 comentarios:
iApple your first link and your second link are identical. Neither one of those is for the service manual
- de
Thanks for notifying me oldturkey03, the link has been replaced with the service manual.
- de
iApple you are funny. The first link is now the user manual, not a service manual. Big differences :-)
- de
Respuesta Más Útil
Cheryl, this video may help. On the bottom of this page is now a pretty good service manual about the adjustment of your sewing machine.
Puntuación 1
Hi Cheryl,
I see it has been almost 7 yrs. since you posted this inquiry, but I have an answer for you. I joined a group called .... BTS@ groups.io ... and found all of the service manuals and user manuals as a free pdf. download. The BTS stands for Bernina Thirtysomething. I tried to send it as a link but it did not work. I sure hope this helps.
Happy sewing!
Puntuación 1
Añadir tu respuesta
Cheryl estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 16
Ultimos 30 días: 73
Todo El Tiempo: 18,495
