Saltar al contenido principal
El Vostro V13 es el ultraportátil empresarial de 13.3" de Dell, dirigido a consumidores en movimiento que buscan un portátil liviano y portátil. Ha sido descontinuado y es comparable al Dell Vostro V131.
Preguntas 1 Ver todo
battery life is getting shorter and shorter
Hi! some months ago I lost my original battery charger, and bought a second hand one, which I thought was compatible. It is a Dell charger, and on the back it reads
"input: 19.5V (19.5V) 4.62A(4.62A)".
Quickly after buying this new charger, however, the battery life started getting shorter, and now sometimes it looks as if the charger was just keeping the pc alive, but as soon as i unplug it the pc turns off instantaneously, just like a desktop would do. This anyway doesn't happen all the time.
What should I do? any suggestions? shall i look for a new charger? is it very costly to buy a new battery?
I care for this pc, and battery apart it still works very well. I wouldn't ike to have to dispose of it!
Thanks!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Respuesta Más Útil
It looks like this model has an issue with the battery i found this information and wanted to pass it along.
What you need to do is take the bottom cover off unseat the ribbon cable and leave it off. While the battery ribbon is off, press and hold the power button and count to 30 seconds.(<--IMPORTANT PART) Reseat the battery ribbon, put the cover back on the bottom (but dont screw it in yet in case that didn't work - sometimes (rarely) you might have to do it 2 times to get it to work).
Pressing the power button should restore battery operation in most cases.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
irenefici estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 8
Todo El Tiempo: 472
