Saltar al contenido principal
Cómo soldar y desoldar conexiones
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Paso 10
How To Solder and Desolder Connections: paso 0, imagen 1 de 2 How To Solder and Desolder Connections: paso 0, imagen 2 de 2
  • Congratulations—you've created a solder joint! Inspect the joint to see if it formed correctly:
  • Leaded solder joints should look like a shiny, concave tent surrounding the entire lead.
  • If the joint isn't shiny, it may not have formed correctly. Reheat the joint briefly and allow it to cool.
  • Lead-free solder joints should look like a concave tent surrounding the entire lead. They may be shiny or dull.
  • If the solder joint doesn't surround the entire lead, reheat the joint and add more solder.
  • If the solder looks like a round bead instead of a concave tent, it didn't bond to the component lead. Reheat the joint and try to get the lead hot enough so the solder bonds to it.
  • Check if any solder unintentionally bridged with a different joint. If so, apply some flux and reheat one of the joints to carefully break the bridge. If the bridge doesn't want to separate follow this step and use solder wick to pull away any extra solder.
  • Like any skill, practice makes perfect. If your first solder joint doesn't look picture-perfect, that's OK! It takes a few attempts to get the hang of the movement and timing.
Enhorabuena: ¡has creado una unión soldada! Inspecciona la unión para ver si se ha formado correctamente:
Las uniones de soldadura con plomo deben verse como una carpa brillante y cóncava que rodea todo el plomo.
Si la unión no está brillante, puede que no se haya formado correctamente. Vuelve a calentar brevemente la unión y deja que se enfríe.
Las juntas de soldadura sin plomo deben tener el aspecto de una tienda de campaña cóncava que rodea todo el plomo. Pueden ser brillantes u opacas.
Si la junta de soldadura no rodea todo el cable, vuelve a calentar la junta y añade más soldadura.
Si la soldadura parece un cordón redondo en lugar de una tienda cóncava, no se ha adherido al cable del componente. Vuelve a calentar la unión e intenta que el cable se caliente lo suficiente para que la soldadura se adhiera a él.
Comprueba si alguna soldadura se ha unido involuntariamente con otra unión. Si es así, aplica un poco de fundente y recalienta una de las uniones para romper el puente con cuidado. Si el puente no quiere separarse, sigue este paso y utiliza mecha de soldadura para retirar la soldadura sobrante.
Como cualquier habilidad, la práctica hace al maestro. Si tu primera soldadura no es perfecta, ¡no pasa nada! Se necesitan varios intentos para cogerle el truco al movimiento y a la sincronización.
