Saltar al contenido principal
MacBook Core 2 Duo Upper Case Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 38 guías que incluyen este paso.
Traduciendo paso 8
Inglés
Holandés
Paso 8
MacBook Core 2 Duo Upper Case Replacement: paso 0, imagen 1 de 3 MacBook Core 2 Duo Upper Case Replacement: paso 0, imagen 2 de 3 MacBook Core 2 Duo Upper Case Replacement: paso 0, imagen 3 de 3
  • While holding up the upper case, pull up the black tab on the connector end of the silver ribbon cable away from the connector's socket on the logic board.
  • If there is no black tab, you can also use a spudger to gently pry the connector out of its socket on the logic board. This connector is tall, so be sure to pry straight up.
  • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
  • While you have the upper case removed, it's a good time to remove dust, hair, etc. It's best to use a can of compressed air, though if you use a brush, make sure that its bristles are made of a material (usually animal hair) that doesn't generate static electricity, which can destroy electronics.
  • Upon reassembly, there are 4 grey plastic clips installed in slots running along the top of the frame in front of the optical drive (refer to second and third pictures). These clips must be installed in their slots for their mating tabs on the underside of the right side of the upper case to snap into them.
Insertar traducción aquí
