Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Paso 4
Slowly peel off the EMI gasket over the ribbon cable assembly.  This will expose the ribbon cable which can be removed from the connectors.
  • Slowly peel off the EMI gasket over the ribbon cable assembly. This will expose the ribbon cable which can be removed from the connectors.
Con cuidado despega la tapa adherida del conector de la clavija con las pinzas.
-[* black] Slowly peel off the cover adhered to the pin connector with the tweezers.
+[* black] Slowly peel off the EMI gasket over the ribbon cable assembly. This will expose the ribbon cable which can be removed from the connectors.
