Saltar al contenido principal
Reemplazo del conjunto de máquina de hielo del refrigerador Samsung
Inglés
Español
Paso 5
Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement: paso 0, imagen 1 de 3 Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement: paso 0, imagen 2 de 3 Samsung Older French Door Refrigerator Upper Icemaker Assembly Replacement: paso 0, imagen 3 de 3
  • Squeeze the locking tab to release the connector and pull it to disconnect.
  • Repeat this for the other connector.
  • Disconnecting both cables will ease removal of the icemaker cable from the cable guide.
Un clip de plástico mantiene la trampilla del túnel de aire en su lugar.
Utiliza un destornillador de punta plana para hacer palanca y aflojar la tapa del túnel de aire del clip de plástico.
-[title] Remove the icemaker assembly
-[* red] A plastic clip holds the air tunnel flap in place.
-[* black] Use a flathead screwdriver to pry and loosen the air tunnel flap from the plastic clip.
+[* black] Squeeze the locking tab to release the connector and pull it to disconnect.
+[* black] Repeat this for the other connector.
+[* icon_note] Disconnecting both cables will ease removal of the icemaker cable from the cable guide.
