Saltar al contenido principal
Google Pixel 8 Pro Screen Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 14 guías que incluyen este paso.
Inglés
Holandés
Paso 4
Google Pixel 8 Pro Screen Replacement, Secure the Anti-Clamp: paso 0, imagen 1 de 3 Google Pixel 8 Pro Screen Replacement, Secure the Anti-Clamp: paso 0, imagen 2 de 3 Google Pixel 8 Pro Screen Replacement, Secure the Anti-Clamp: paso 0, imagen 3 de 3
  • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
  • For complete instructions on how to use the Anti-Clamp, check out this guide.
  • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
  • Place your phone screen side up on an object so it will rest level between the Anti-Clamp's arms—the bottom edge should be hanging off.
  • Slide the arms over the left edge of your phone, so you have access to the bottom edge.
  • Position the suction cups as close to the center of the bottom edge as possible.
  • Squeeze the cups together to create suction.
Insertar traducción aquí
