Saltar al contenido principal
Retiro de conjunto de Panel Frontal
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 14 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 7
Paso 7
Front Panel Assembly Removal, Remove the front panel assembly: paso 0, imagen 1 de 3 Front Panel Assembly Removal, Remove the front panel assembly: paso 0, imagen 2 de 3 Front Panel Assembly Removal, Remove the front panel assembly: paso 0, imagen 3 de 3
  • Remove the front panel assembly.
  • Use an opening pick to cut away any residual adhesive that may still be connecting the front panel assembly to the frame.
  • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit replacement digitizers come with the proper insulation and should not require the addition of any tape.
  • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
  • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
  • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
  • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
Retira el conjunto del panel frontal.
Usa una púa de apertura para cualquier cualquier adhesivo que aún pueda seguir conectando el conjunto del panel frontal al marco.
Si experimentas problemas al tacto "fantasmas" con tu display nuevo, esto se puede solucionar añadiendo una capa de cinta aislante muy delgada, como cinta poliamida Kapton a las áreas resaltadas en la parte trasera del panel. Los digitalizadores de reemplazo iFixit vienen con aislamiento apropiado y no requieren cinta adhesiva adicional.
Sin el aislamiento apropiado, estas áreas del digitalizador pueden hacer tierra con otros componentes, causando un problema en la entrada touch.
El asilamiento no es visible ante el ojo humano, y es diferente del polvo de espuma que se encuentra en varias iPads.
Durante el reensamble, antes de instalar un display, retira cualquier adhesivo restante de la iPad y limpia las áreas con pegamento con alcohol isopropílico de alta concentración (90% o más) y un trapo libre de pelusa. Esto ayuda a preparar el iPad para el adhesivo fresco y asegura que pegue propiamente.
Prueba las funciones de tu iPad e instala cintas de ahesivo pre-cortadas a la aprte trasera del display usando nuestra guía de aplicación de adhesivo antes de sellarla.
