Saltar al contenido principal
Sustitución de la RAM del Toshiba Satellite A105-S4011
Inglés
Español
Paso 2
Toshiba Satellite A105-S4011 RAM Replacement: paso 0, imagen 1 de 1
  • Using a plastic opening tool, pop off the back cover. Your going to insert the tool into the small slit located on the back cover piece.
  • Be careful when prying the back cover off because you may damage the cover or crack the plastic.
Con una herramienta de apertura de plástico, saca la tapa trasera. Vas a insertar la herramienta en la pequeña ranura ubicada en la pieza de la cubierta trasera.
Ten cuidado al hacer palanca para quitar la tapa trasera porque puedes dañar la tapa o romper el plástico.
-[* black] Using a plastic opening tool, pop off the back cover. Your going to insert the tool into the small slit located on the back cover piece.
+[* red] Using a plastic opening tool, pop off the back cover. Your going to insert the tool into the small slit located on the back cover piece.
[* icon_caution] Be careful when prying the back cover off because you may damage the cover or crack the plastic.
