Saltar al contenido principal
Desmontaje del iPad 11"
Inglés
Español
Paso 15
iPad Pro 11" Teardown: paso 0, imagen 1 de 3 iPad Pro 11" Teardown: paso 0, imagen 2 de 3 iPad Pro 11" Teardown: paso 0, imagen 3 de 3
  • Next to come out is the Pencil charging board, with its copper charging coils attached.
  • While it's technically out, it's not without casualty...
  • Tiny capacitors and other board bits go flying in protest as we remove the shields. Are we sorry? No we're not.
  • What's this we see, hiding in the corner? It's an STMicroelectronics STM32L476JGY6 ARM Cortex MCU.
  • Texas Instruments TPS60151 5V charge pump
  • ON Semiconductor FPF1204UCX Load Switch
Lo próximo en salir es la placa de carga de Lápiz con sus bobinas de carga de bronce.
Si bien está técnicamente fuera, no se va sin dejar víctimas...
Capacitadores pequeñísimos y otros trozos de placa salen volando en protesta cuando removemos los escudos. ¿Lo lamentamos? Por supuesto que no.
¿Qué es esto que estamos viendo escondido en la esquina? Es un STMicroelectronics STM32L476JGY6 ARM Cortex MCU.
[* black] Next to come out is the Pencil charging board, with its copper charging coils attached.
[* black] While it's technically out, it's not without casualty...
[* black] Tiny capacitors and other board bits go flying in protest as we remove the shields. Are we sorry? No we're not.
[* red] What's this we see, hiding in the corner? It's an STMicroelectronics [https://www.st.com/resource/en/datasheet/stm32l476rg.pdf|STM32L476JGY6|new_window=true] ARM Cortex MCU.
+[* orange] Texas Instruments [link|https://www.ti.com/product/TPS60151|TPS60151] 5V charge pump
+[* yellow] ON Semiconductor [link|https://www.onsemi.com/products/power-management/load-switches/fpf1204ucx|FPF1204UCX] Load Switch
