Saltar al contenido principal
Xbox Series X 2TB Galaxy Black Southbridge Board Replacement
Spencer Day
Spencer Day y otro contribuidor
Última actualización: January 30, 2025
30 minuto - 1 hora
Moderado
Introducción
Ir al paso 1
Use this guide to replace the southbridge board on an Xbox Series X (2TB Galaxy Black edition).
Before you begin, completely power down and unplug all cables from your console. Remember to follow general electrostatic discharge (ESD) safety procedures while repairing the console.
Qué necesitas
Herramientas
Ver más…
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Uncover the back panel screws: paso 1, imagen 1 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Uncover the back panel screws: paso 1, imagen 2 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Uncover the back panel screws: paso 1, imagen 3 de 3
    • Before you begin, completely power down and unplug all cables from your console.
    • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  2. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 2, imagen 1 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 2, imagen 2 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 2, imagen 3 de 3
    • For cleaner removal, use an iOpener or hair dryer to heat the sticker.
    • Use a pair of blunt tweezers to peel back the large sticker on the back panel to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
  3. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the back panel screws: paso 3, imagen 1 de 2 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the back panel screws: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Magnetic Project Mat
    $19.95
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  4. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Unclip the back panel: paso 4, imagen 1 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Unclip the back panel: paso 4, imagen 2 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Unclip the back panel: paso 4, imagen 3 de 3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  5. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 5, imagen 1 de 2 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 5, imagen 2 de 2
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  6. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the back panel: paso 6, imagen 1 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the back panel: paso 6, imagen 2 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the back panel: paso 6, imagen 3 de 3
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  7. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 7, imagen 1 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 7, imagen 2 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 7, imagen 3 de 3
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  8. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the fan screws: paso 8, imagen 1 de 1
    • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
    • One 10.5 mm pancake screw
    • Two 8.8 mm screws
  9. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Disconnect the fan cable: paso 9, imagen 1 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Disconnect the fan cable: paso 9, imagen 2 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Disconnect the fan cable: paso 9, imagen 3 de 3
    • Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
    • Always pull cables by their connectors and not the wires themselves.
    • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
  10. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the fan: paso 10, imagen 1 de 2 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the fan: paso 10, imagen 2 de 2
    • Slide the fan out of its slot to remove it.
    • During reinstallation, note that the fan can only be installed one way—make sure Master Chief is facing you.
    • If you're replacing the fan, a new fan might not include the plastic installation bracket, which is attached to the fan with four T10 Torx screws. This isn't pictured in this guide.
  11. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Unlatch the base: paso 11, imagen 1 de 2 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Unlatch the base: paso 11, imagen 2 de 2
    • Use the flat end of a spudger to lift up on the locking tab holding the base to the shell.
  12. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Twist and remove the base: paso 12, imagen 1 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Twist and remove the base: paso 12, imagen 2 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Twist and remove the base: paso 12, imagen 3 de 3
    • With the locking tab held open, grip the base and rotate it counterclockwise to unlock it from the shell.
    • Remove the base.
    • During reassembly, put the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the "Hello from Seattle" line will be parallel with the device's sides.
  13. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the optical drive screws: paso 13, imagen 1 de 2 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the optical drive screws: paso 13, imagen 2 de 2
    • Use a T8 Torx driver to remove the two 8.8 mm screws securing the optical drive's vibration isolator to the shell: one on the base and one on the top of the isolator.
  14. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the vibration isolator: paso 14, imagen 1 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the vibration isolator: paso 14, imagen 2 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the vibration isolator: paso 14, imagen 3 de 3
    • Lift up the optical drive's vibration isolator to remove it.
    • The vibration isolator grips the sides of the optical drive with silicone pads, so you may need to "walk" the isolator off of the drive to slip it off each side.
    • During reassembly, ensure the vibration isolator is pushed down and around both edges of the optical drive, so it sits flush with the rest of the center chassis.
  15. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Disconnect the power and data cables: paso 15, imagen 1 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Disconnect the power and data cables: paso 15, imagen 2 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Disconnect the power and data cables: paso 15, imagen 3 de 3
    • Use a pair of blunt tweezers to grip the edges of the optical drive power connector and pull up to disconnect it from the optical drive.
    • Use your fingers to pull up and disconnect the data cable from the optical drive.
  16. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the optical drive: paso 16, imagen 1 de 2 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the optical drive: paso 16, imagen 2 de 2
    • Grip the top edge of the optical drive and pull it out of its slot in the shell to remove it.
    • During reassembly, align the pegs on the bottom edge of the optical drive with the guide holes on the bottom of the shell.
    • If the drive is misaligned, the top vibration isolator will not be able to be installed correctly, and the disc reader will be misaligned with the front of the console.
  17. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Xbox Series X 2TB Galaxy Black Chassis Removal: paso 17, imagen 1 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Xbox Series X 2TB Galaxy Black Chassis Removal: paso 17, imagen 2 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Xbox Series X 2TB Galaxy Black Chassis Removal: paso 17, imagen 3 de 3
    • The ribbon cables and their connectors are extremely fragile, so always open locking tabs gently and pull cables slowly.
    • Use the flat end of a spudger to flip open the metal locking tab on the USB port ribbon cable.
    • During reassembly, gently snap the metal locking tab back into place once the cable has been inserted.
  18. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 18, imagen 1 de 2 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 18, imagen 2 de 2
    • Use a pair of tweezers to pull up on the black plastic pull tab to disconnect the USB port cable.
    • Pull only on the pull tab, not the cable itself.
    • If the USB port cable feels adhered to the metal chassis, use an apply an iOpener or hair dryer to heat the cable. Depending on your model of Xbox, you may also need to slide an opening pick under the cable to separate the adhesive.
  19. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Disconnect the power button cable: paso 19, imagen 1 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Disconnect the power button cable: paso 19, imagen 2 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Disconnect the power button cable: paso 19, imagen 3 de 3
    • Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
    • With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
    • Don't pull on the cable without depressing the metal tab, otherwise you risk damaging either the cable or the connector.
    • During reassembly, the cable should lightly "snap" into place when inserted.
  20. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the chassis screws: paso 20, imagen 1 de 2 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the chassis screws: paso 20, imagen 2 de 2
    • Use a T8 Torx driver to remove the three 7.4 mm screws securing the center chassis assembly to the shell.
  21. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 21, imagen 1 de 2 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 21, imagen 2 de 2
    • Gently peel the taped USB port ribbon cable off of the heatsink.
    • Depending on your model of Xbox, the adhesive may be on the underside of the cable. If so, use an iOpener or hair dryer to heat the cable.
  22. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 22, imagen 1 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 22, imagen 2 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 22, imagen 3 de 3
    • The center chassis assembly is aligned to the bottom of the shell with guide pegs. These pegs will need to slide out of their slots to allow the chassis to be lifted out.
    • Grip the chassis and pull it towards the top of the shell, uncoupling the guide pegs from the shell.
    • Use two hands to lift out the chassis to remove it from the shell.
    • During reassembly, make sure neither of the ribbon cables get pinched as you lower the center chassis into the shell.
  23. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 23, imagen 1 de 2 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 23, imagen 2 de 2
    Dust Blower
    • Gently place the chassis heatsink-side down on a clean work surface.
    • During reassembly, this is a good point to clean the heatsink fins of any dust, dirt, or debris that may have built up over time. Use a dust blower or compressed air to clear out the fins.
  24. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the antenna board screws: paso 24, imagen 1 de 2 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the antenna board screws: paso 24, imagen 2 de 2
    • Use a T8 Torx driver to remove the three 9.6 mm‑long screws securing the antenna board to the center chassis.
  25. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the accessory antenna board: paso 25, imagen 1 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the accessory antenna board: paso 25, imagen 2 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the accessory antenna board: paso 25, imagen 3 de 3
    • Grip the top right corner of the antenna board and pull it directly away from the center chassis to disconnect it.
    • During reassembly, align the board's connector with the port on the center chassis and press to reconnect.
  26. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the power cable port: paso 26, imagen 1 de 2 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the power cable port: paso 26, imagen 2 de 2
    • Use a T8 Torx driver to remove the three screws securing the power cable port to the chassis:
    • Two 13.1 mm‑long screws
    • One 35 mm‑long screw
  27. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 27, imagen 1 de 2 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 27, imagen 2 de 2
    • Lift the power connector out of its recess in the chassis.
  28. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, De-route the power cables: paso 28, imagen 1 de 2 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, De-route the power cables: paso 28, imagen 2 de 2
    • Unlatch and open the lid on the power cable's plastic guide.
  29. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 29, imagen 1 de 2 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 29, imagen 2 de 2
    • Lift the power cable out from underneath the extra section of the cable guide.
  30. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the board shield: paso 30, imagen 1 de 2 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the board shield: paso 30, imagen 2 de 2
    • Use a T8 Torx driver to remove the ten screws securing the board shield:
    • Seven 8.7 mm‑long screws
    • Two 35 mm‑long screws
    • These screws are very tight and may take significant force to loosen.
    • One 13 mm‑long screw
  31. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 31, imagen 1 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 31, imagen 2 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 31, imagen 3 de 3
    • Hold the power supply cable out of the way and lift the board shield straight up to remove it.
  32. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Disconnect the power supply cables: paso 32, imagen 1 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Disconnect the power supply cables: paso 32, imagen 2 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Disconnect the power supply cables: paso 32, imagen 3 de 3
    • Open the lid on the power supply's plastic cable guide.
  33. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 33, imagen 1 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 33, imagen 2 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 33, imagen 3 de 3
    • Use your fingers to pinch the power supply's two‑pin power connector, so the locking tab opens outward.
    • With the locking tab open, lift the connector straight up and out of its socket.
  34. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 34, imagen 1 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 34, imagen 2 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 34, imagen 3 de 3
    • Repeat the previous step to disconnect the power supply's 10‑pin connector.
  35. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Unlatch the chassis strap: paso 35, imagen 1 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Unlatch the chassis strap: paso 35, imagen 2 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Unlatch the chassis strap: paso 35, imagen 3 de 3
    • Pull the end of the rubber strap down and away from the chassis to unlatch it.
  36. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 36, imagen 1 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 36, imagen 2 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 36, imagen 3 de 3
    • Pull the chassis strap off its three alignment posts and unlatch it from the sides of the power supply.
    • You can leave the strap under the chassis or remove it.
    • During reassembly, make sure the nubs in the middle of the strap go unto their cutouts on the heat sink fins.
  37. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the power supply screws: paso 37, imagen 1 de 2 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the power supply screws: paso 37, imagen 2 de 2
    • Use a T8 Torx driver to remove the four screws securing the corners of the power supply:
    • Three 35 mm‑long silver screws
    • One 8.7 mm‑long black screw
  38. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the power supply: paso 38, imagen 1 de 2 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the power supply: paso 38, imagen 2 de 2
    • Lift the power supply straight up and remove it.
  39. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the Wi‑Fi board: paso 39, imagen 1 de 2 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the Wi‑Fi board: paso 39, imagen 2 de 2
    • Use a T8 Torx driver to remove the three 8.7 mm‑long screws securing the Wi-Fi antenna board.
  40. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 40, imagen 1 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 40, imagen 2 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 40, imagen 3 de 3
    • Don't pull up on the antenna board until it's completely disconnected.
    • Grip the antenna board and pull it directly away from the center chassis to disconnect it.
    • Remove the antenna board.
  41. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Disconnect the interconnect cable: paso 41, imagen 1 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Disconnect the interconnect cable: paso 41, imagen 2 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Disconnect the interconnect cable: paso 41, imagen 3 de 3
    • Use your fingers to pinch the locking tab in the center of the interconnect cable connector.
    • While pinching the tab, insert the flat end of a spudger between the top of the socket and the connector's tab.
    • Twist the spudger to lift the connector out of its socket until the clip in the center disengages.
  42. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 42, imagen 1 de 2 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 42, imagen 2 de 2
    • Use your fingers to pull the connector straight up and out of its socket.
    • During reassembly, insert the interconnect cable connector into its socket and press down on both edges until the connector snaps into place.
  43. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the center chassis: paso 43, imagen 1 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the center chassis: paso 43, imagen 2 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the center chassis: paso 43, imagen 3 de 3
    • Lift the center chassis off the motherboard and heatsink assembly, routing the interconnect cable through its cutout.
  44. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the southbridge board shield: paso 44, imagen 1 de 2 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the southbridge board shield: paso 44, imagen 2 de 2
    • Use a T8 Torx driver to remove the seven 8.7 mm‑long screws securing the southbridge board shield.
  45. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 45, imagen 1 de 2 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement: paso 45, imagen 2 de 2
    • Remove the board shield.
  46. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the cable guide: paso 46, imagen 1 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the cable guide: paso 46, imagen 2 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the cable guide: paso 46, imagen 3 de 3
    • Lift up to remove the power supply cable guide from the southbridge board.
    • During reassembly, insert the post with a tab into its screw hole first before aligning the rest of the cable guide.
  47. Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the southbridge board: paso 47, imagen 1 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the southbridge board: paso 47, imagen 2 de 3 Xbox Series X 2TB Galaxy Black Southbridge Board Replacement, Remove the southbridge board: paso 47, imagen 3 de 3
    • Remove the southbridge board from the center chassis.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
Spencer Day
Miembro Desde 09/14/22
95,018 Reputación
662 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
118 Miembros
19,455 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 25
Todo El Tiempo: 109
