Saltar al contenido principal
Cricut Maker Motor Replacement
Collin Kidd
Collin Kidd y 3 otros contribuidores
Última actualización: May 9, 2024
1 - 2 horas
Difícil
Necesita mejores imágenes
Necesita más imágenes
Introducción
Ir al paso 1
The Circut Maker it is powered by two motors. If your device isn't moving at all, and it's still receiving power, then the motors might need to be replaced. The motors are not identical, so be sure to identify which one is faulty before beginning.
Before beginning the repair, be sure to turn off the device and unplug it from the outlet.
Qué necesitas
Herramientas
Ver más…
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Cricut Maker Motor Replacement, Cricut Maker Lid Replacement: paso 1, imagen 1 de 3 Cricut Maker Motor Replacement, Cricut Maker Lid Replacement: paso 1, imagen 2 de 3 Cricut Maker Motor Replacement, Cricut Maker Lid Replacement: paso 1, imagen 3 de 3
    • To remove the cover from the connecting joint, use an iFixit opening tool, and pry around the perimeter of the cover to release it.
    • Applying too much pressure to this can break it as it is very fragile.
    • There is some adhesive holding the cover, so it may take some patience and finesse to pry the cover off.
    • Remove the cover from the connecting joint and set it aside.
  2. Cricut Maker Motor Replacement: paso 2, imagen 1 de 2 Cricut Maker Motor Replacement: paso 2, imagen 2 de 2
    • Remove the four, 10 mm Torx TR8 security screws holding the lid in place.
  3. Cricut Maker Motor Replacement: paso 3, imagen 1 de 3 Cricut Maker Motor Replacement: paso 3, imagen 2 de 3 Cricut Maker Motor Replacement: paso 3, imagen 3 de 3
    • Turn the device around, so that the back is facing you.
    • Look for the small rectangles along the back of the device. For every two rectangles, there is one cylindrical connector in between the two.
    • Wedge one or two iFixit opening picks in the seam connecting the Top Door to the device, and use the iFixit opening tool to pry upwards along the seam.
    • These actions should reveal the cylindrical connectors.
  4. Cricut Maker Motor Replacement: paso 4, imagen 1 de 1
    • Press down on the lid.
    • Push the lid outwards to free it from the jointed clasps.
  5. Cricut Maker Motor Replacement, Front Door Replacement: paso 5, imagen 1 de 2 Cricut Maker Motor Replacement, Front Door Replacement: paso 5, imagen 2 de 2
    • Using your hands or an opening tool, remove the four foot pads covering four screws.
    • Use a Phillips #1 screwdriver to remove four 41 mm screws from the feet.
  6. Cricut Maker Motor Replacement: paso 6, imagen 1 de 3 Cricut Maker Motor Replacement: paso 6, imagen 2 de 3 Cricut Maker Motor Replacement: paso 6, imagen 3 de 3
    • Remove the seven screws (Four 8.5 mm screws, and three 12.5 mm screws) on the bottom of the device, this will allow you to remove the cover later on.
    • Use a Phillips #1 screwdriver to remove the four 8.5 mm screws from the bottom of the device.
    • Use a Phillips #0 screwdriver to remove the three 12.5 mm screws.
  7. Cricut Maker Motor Replacement: paso 7, imagen 1 de 3 Cricut Maker Motor Replacement: paso 7, imagen 2 de 3 Cricut Maker Motor Replacement: paso 7, imagen 3 de 3
    • Turn the device on its side.
    • To remove the seven 10 mm screws from the underside of the top of the device, use a Phillips #1 screwdriver with the flex extension.
  8. Cricut Maker Motor Replacement: paso 8, imagen 1 de 3 Cricut Maker Motor Replacement: paso 8, imagen 2 de 3 Cricut Maker Motor Replacement: paso 8, imagen 3 de 3
    • Lift the top case off of the base of the device.
    • After removing this cover, the internals of the device will be exposed.
  9. Cricut Maker Motor Replacement: paso 9, imagen 1 de 2 Cricut Maker Motor Replacement: paso 9, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove four 10 mm screws on the side of the device next to the motors.
    • Use a Phillips #1 screwdriver to remove the two 22 mm screws.
  10. Cricut Maker Motor Replacement: paso 10, imagen 1 de 3 Cricut Maker Motor Replacement: paso 10, imagen 2 de 3 Cricut Maker Motor Replacement: paso 10, imagen 3 de 3
    • Use a Phillips #1 screwdriver to remove two 10 mm screws. These are parallel to one another, one on either side of the machine.
    • Use a Phillips #1 screwdriver to remove two 8mm screws, these are also directly parallel to one another on either side of the machine.
  11. Cricut Maker Motor Replacement: paso 11, imagen 1 de 2 Cricut Maker Motor Replacement: paso 11, imagen 2 de 2
    • Unplug the bundled connector from the motor on both sides of the machine. To to avoid damage, coax the connector out of the socket gently using a spudger.
  12. Cricut Maker Motor Replacement: paso 12, imagen 1 de 2 Cricut Maker Motor Replacement: paso 12, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove one 10 mm screw from both sides of the machine. This will release wires that are screwed into the sides of device.
    • Once the screws are removed and wires detached, the main body can be lifted off the base, and set aside.
  13. Cricut Maker Motor Replacement: paso 13, imagen 1 de 3 Cricut Maker Motor Replacement: paso 13, imagen 2 de 3 Cricut Maker Motor Replacement: paso 13, imagen 3 de 3
    • Remove a total of seven 10 mm screws from the underside of the door.
    • One side of the base has two 10mm screws.
    • The other side of the base has five 10 mm screws.
  14. Cricut Maker Motor Replacement: paso 14, imagen 1 de 3 Cricut Maker Motor Replacement: paso 14, imagen 2 de 3 Cricut Maker Motor Replacement: paso 14, imagen 3 de 3
    • Pry the door from hinges using an iFixit opening tool.
    • Lift upwards and towards you, to remove the door from the hinges.
  15. Cricut Maker Motor Replacement, Motor: paso 15, imagen 1 de 2 Cricut Maker Motor Replacement, Motor: paso 15, imagen 2 de 2
    • Use a Phillips #1 screwdriver to remove the four 5 mm screws that attach the motor on the left side of the machine.
  16. Cricut Maker Motor Replacement: paso 16, imagen 1 de 1
    • Remove the motor by pulling it from the device.
  17. Cricut Maker Motor Replacement: paso 17, imagen 1 de 1
    • Under the motor there is a white plastic gear. To remove it, gently pull it off the axle.
  18. Cricut Maker Motor Replacement: paso 18, imagen 1 de 2 Cricut Maker Motor Replacement: paso 18, imagen 2 de 2
    • Remove the washer from the top screw above the motor.
    • We found it was easier done by hand.
  19. Cricut Maker Motor Replacement: paso 19, imagen 1 de 2 Cricut Maker Motor Replacement: paso 19, imagen 2 de 2
    • Remove the two 5 mm screws from the remaining motor on the opposite side, using a Phillips #2 screwdriver.
  20. Cricut Maker Motor Replacement: paso 20, imagen 1 de 2 Cricut Maker Motor Replacement: paso 20, imagen 2 de 2
    • Twist and remove the motor from the machine.
    • Avoid touching the various tach disks on these motors.
Conclusión
2 personas más completaron esta guía.
Collin Kidd
Miembro Desde 09/20/22
160 Reputación
1 Guía escrita
Equipo
2 comentarios
Bonjour,
Merci pour vos précisions c’est parfait comme tuto mais quels sont les signaux de la cricut nous alarmant que c’est une panne de moteur ? Car ma machine en l’occurrence fait un drôle de bruit au démarrage mais je ne sais pas d’où vient la panne ni le centre d’assistance de cricut d’ailleurs à part me conseiller d’en acheter une autre. Pouvez-vous peut-être me conseiller ?
Merci d’avance
Fanny
Fanny Houitte-Marion - Contestar
Convenient that the tools list doesn't have the flex extension. Great directions dick face.
Nick - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 39
Ultimos 30 días: 108
Todo El Tiempo: 3,192
